OpenAI image generation in 5 minutes
saw a video about OpenAI image generation and I had to try it out. Naturally node-red made this a 5 minute job.
        "id": "c2883a331c36842f",
        "type": "tab",
        "label": "OpenAI",
        "disabled": false,
        "info": "",
        "env": []
        "id": "1de2dab24e4aea36",
        "type": "function",
        "z": "c2883a331c36842f",
        "name": "function 1",
        "func": "msg.url = \"https://api.openai.com/v1/images/generations\";\nmsg.method = \"POST\";\nvar prompt = msg.payload;\nvar n = 2;\nvar size = \"512x512\";\n\nmsg.payload = {\n    \"prompt\": prompt,\n    \"n\": n,\n    \"size\": size,\n};\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 740,
        "y": 200,
                "b5c4b9a30cd04582"
        "id": "b5c4b9a30cd04582",
        "type": "http request",
        "method": "use",
        "ret": "obj",
        "paytoqs": "ignore",
        "url": "",
        "tls": "",
        "persist": false,
        "proxy": "",
        "insecureHTTPParser": false,
        "authType": "bearer",
        "senderr": false,
        "headers": [],
        "x": 950,
        "y": 200,
                "0a851b5ea2c3db75"
        "id": "af927ae24f9e9018",
        "type": "ui_text_input",
        "name": "Prompt",
        "label": "Enter a Prompt, like \"Paddleboarding with a scarecrow at sunset\"",
        "tooltip": "Enter a prompt!",
        "group": "dcc461615ad026bf",
        "order": 1,
        "width": 0,
        "height": 0,
        "passthru": true,
        "mode": "text",
        "delay": 300,
        "topic": "",
        "x": 440,
        "y": 120,
                "b717e2dd116b0935"
        "id": "7d109687b80b952a",
        "type": "ui_button",
        "order": 2,
        "width": 0,
        "height": 0,
        "passthru": false,
        "label": "submit",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "icon": "",
        "payload": "prompt",
        "payloadType": "flow",
        "topic": "",
        "x": 470,
        "y": 200,
                "1de2dab24e4aea36"
        "id": "b717e2dd116b0935",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "prompt",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 760,
        "y": 120,
        "id": "0a851b5ea2c3db75",
        "type": "ui_template",
        "order": 3,
        "width": 0,
        "height": 0,
        "format": "<div layout=\"row\" layout-align=\"space-between\">\n    \n    <img src=\"{{msg.payload.data[0].url}}\">\n    <img src=\"{{msg.payload.data[1].url}}\">\n\n  \n</div>\n\n",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "x": 1160,
        "y": 200,
        "id": "dcc461615ad026bf",
        "type": "ui_group",
        "name": "OpenAI demo",
        "tab": "308f09ba75c30f2f",
        "disp": true,
        "width": "20",
        "collapse": false
        "id": "308f09ba75c30f2f",
        "type": "ui_tab",
        "name": "OpenAI",
        "icon": "dashboard",
        "order": 1,
        "disabled": false,
        "hidden": false
Inspired by your json,
I made video how to run OpenAI in node-red
Thank you
I tested, it fast to generate the images
Video:
