Hello guys, i get this error when i try to install openplc for node-red
Please follow
https://nodered.org/docs/user-guide/runtime/adding-nodes
Yes, well i have now and i get the same error, tried install from terminal in the node red dir and tried from the editor. tried installing serial port separate.
this is the error from the editor
and this does not exist
i know, but i tried reinstall it, why does not openplc recognize its there?
Hi...Having the same problem: node-red-node-serialport v0.10.0 installed and does not recognize install:
serialport.target.mk:109: recipe for target 'Release/obj.target/serialport/src/serialport.o' failed
make: *** [Release/obj.target/serialport/src/serialport.o] Error 1
make: Leaving directory '/home/pi/.node-red/node_modules/node-modbus/node_modules/serialport/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! stack at ChildProcess.emit (events.js:210:5)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:272:12)
gyp ERR! System Linux 4.14.98-v7+
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/home/pi/.node-red/node_modules/node-modbus/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/home/pi/.node-red/node_modules/node-modbus/node_modules/serialport/build/Release"
gyp ERR! cwd /home/pi/.node-red/node_modules/node-modbus/node_modules/serialport
gyp ERR! node -v v12.13.1
gyp ERR! node-gyp -v v5.0.5
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/home/pi/.node-red/node_modules/node-modbus/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/home/pi/.node-red/node_modules/node-modbus/node_modules/serialport/build/Release' (1)
node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/home/pi/.node-red/node_modules/node-modbus/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:210:5)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1021:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)
node-pre-gyp ERR! System Linux 4.14.98-v7+
node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/.node-red/node_modules/node-modbus/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /home/pi/.node-red/node_modules/node-modbus/node_modules/serialport
node-pre-gyp ERR! node -v v12.13.1
node-pre-gyp ERR! node-pre-gyp -v v0.6.32
node-pre-gyp ERR! not ok
gyp ERR! not ok
npm WARN notsup Unsupported engine for node-red-contrib-modbus@1.3.0: wanted: {"node":"6.x"} (current: {"node":"12.13.1","npm":"6.13.3"})
npm WARN notsup Not compatible with your version of node/npm: node-red-contrib-modbus@1.3.0
npm WARN node-red-contrib-ui-led@0.3.1 requires a peer of node-red-dashboard@2.14.x but none is installed. You must install peer dependencies yourself.
npm WARN node-red-project@0.0.1 No repository field.
npm WARN node-red-project@0.0.1 No license field.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! serialport@4.0.7 install: `node-pre-gyp install --fallback-to-build`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the serialport@4.0.7 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
Any advice?
And you installed this using the editor ? (menu -> manage palette -> install tab -> search serial, install ?)
Via UI or CLI, results are the same...
maybe try with --unsafe-perm option
cd ~/.node-red
npm i --unsafe-perm node-red-node-serialport@latest
Though I note later on the modbus node is complaining about the version of nodejs... which is bad... as node6 is out of support. So either the node should stop being used/uninstalled or fixed.
Unfortunately did not work. I uninstalled modbus and serialport followed by;
cd ~/.node-red
npm install node-red-contrib-openplc
But no campaign ....
node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/home/pi/.node-red/node_modules/modbus-serial/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/home/pi/.node-red/node_modules/modbus-serial/node_modules/serialport/build/Release' (1)
node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/home/pi/.node-red/node_modules/modbus-serial/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/.node-red/node_modules/modbus-serial/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /home/pi/.node-red/node_modules/modbus-serial/node_modules/serialport
serialport.target.mk:109: recipe for target 'Release/obj.target/serialport/src/serialport.o' failedipt
make: Leaving directory '/home/pi/.node-red/node_modules/modbus-serial/node_modules/serialport/build'
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/home/pi/.node-red/node_modules/modbus-serial/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/home/pi/.node-red/node_modules/modbus-serial/node_modules/serialport/build/Release"
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /home/pi/.npm/_logs/2019-12-15T21_14_32_313Z-debug.log
Ah right yes - they are trying to install serialport@4.0.7 which is too old for node v12. This seems to be coming from their dependency on node-red-contrib-modbus - which indeed has been having issues of late.
Thank you for your reply...According to node-red-modbus github, NodeJS v12 is not supported.
