Options to resend command once
I use different flows in Home Assistant to send commands to several devices via a RFXCOM module (433 MHz). In some cases these commands are not received by the device. Therefore I want to resend the command once again after one minute to be sure that the command will be executed. I started to use the looptimer node, but this node continues to run, also when I change the max loops number to 1. Is there any other way to make sure that a command will be resend after a specific time? Thanks in advance for your reaction.
Add a delay node set to 60s in parallel
Thanks dceejay, adding the delay node worked as a charm! The picture below shows the final result.
