I want to sweep a 360 degree servo for 4 seconds to the right then delay for 5 seconds then sweep the servo to the left for 4 seconds then delay for 5 seconds then repeat till I send a stop command. I can move the servo but in the function node I don't know how to write the script.
So I need a delay or seTimeout and a loop to do so. Thank you. Ron.
You don't give us much to go on here, but I would suggest you look at the trigger node.
thank you that did what i was trying to do BUT,, I don't know how to stop it. how do i send my flow so you could have a bit more info to help me I don't remember how to do that. Ron. """ or ... i don,t know.
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
code goes here
You can edit and correct your post by clicking the pencil
icon.
