Hello, i have a problem with flow that controls servo motor via twitter node.
When i receive tweet with given keyword the servo should go at 120 waits 5s. and goes to 0.
The problem is that i receive error in my debug node and servo doesn't move. The servo is attached to gpio 17 of raspberry pi.
this is the flow:
[{"id":"5d6934db.e0f25c","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"be759770.bc8b18","type":"twitter in","z":"5d6934db.e0f25c","twitter":"","tags":"testdog11","user":"false","name":"","inputs":0,"x":220,"y":100,"wires":[["f1915a17.e572f8"]]},{"id":"8ee7f69c.772ce8","type":"debug","z":"5d6934db.e0f25c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":770,"y":60,"wires":[]},{"id":"f1915a17.e572f8","type":"change","z":"5d6934db.e0f25c","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"120","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":80,"wires":[["8ee7f69c.772ce8","bb385c43.b5cc3","c13e326d.d8ac5"]]},{"id":"bb385c43.b5cc3","type":"rpi-gpio out","z":"5d6934db.e0f25c","name":"Servo pin","pin":"3","set":"","level":"0","freq":"","out":"pwm","x":720,"y":140,"wires":[]},{"id":"c13e326d.d8ac5","type":"delay","z":"5d6934db.e0f25c","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":460,"y":180,"wires":[["76814639.6c7e38"]]},{"id":"76814639.6c7e38","type":"change","z":"5d6934db.e0f25c","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":260,"wires":[["2e668e3d.bd0982","bb867fa0.c9a04"]]},{"id":"2e668e3d.bd0982","type":"debug","z":"5d6934db.e0f25c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":850,"y":320,"wires":[]},{"id":"bb867fa0.c9a04","type":"rpi-gpio out","z":"5d6934db.e0f25c","name":"Servo pin","pin":"11","set":"","level":"0","freq":"","out":"out","x":860,"y":200,"wires":[]}]
