Parsing txt file
Hello there , I am new to Node-red and I`d like to know how do I can parse text from a file and display it on my dashboard ... My dashboard is ready and working but idk how to parse the "Menu1" word from my txt file ... the first node that opens the file works (the entire content of the file appears in the debug) but still cant parse a word in ...
Here is the code in my parsing node ;
if (!context.count){
context.count = 20;
parsed = parseInt(msg.payload);
if(parsed==1){
context.count++;
msg.payload = context.count;
and here is the debug tab :
03/04/2019 à 11:02:45node: 9fb6b5f3.404608
msg.payload : string[29]
"Menu1 \t fasfdfds \t fghsd \t"
03/04/2019 à 11:02:45node: 40c35d07.249254
msg.payload.variable_1 : undefined
undefined
as you can see , it can read in the file but dont recognise the word "Menu1" in it..
Thanks for help and spending your time reading this
here is the parsing flow :
[{"id":"9aed556e.760008","type":"tab","label":"parse","disabled":false,"info":""},{"id":"b2db9145.f5b1","type":"inject","z":"9aed556e.760008","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":420,"y":80,"wires":[["a3ab124e.5f21a"]]},{"id":"a3ab124e.5f21a","type":"file in","z":"9aed556e.760008","name":"access to file","filename":"/home/pi/Desktop/sms/messages","format":"utf8","chunk":false,"sendError":true,"encoding":"utf8","x":170,"y":180,"wires":[["9fb6b5f3.404608","a8c43f28.32aed"]]},{"id":"881d70a9.606ec","type":"function","z":"9aed556e.760008","name":"recherche du mot Menu1","func":"if (!context.count){\n context.count = 20;\n}\nparsed = parseInt(msg.payload);\nif(parsed==1){\n context.count++;\n }\n\nmsg.payload = context.count;\nreturn msg;\n","outputs":1,"noerr":0,"x":510,"y":160,"wires":[]},{"id":"40c35d07.249254","type":"debug","z":"9aed556e.760008","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload.variable_1","targetType":"msg","x":450,"y":360,"wires":},{"id":"9fb6b5f3.404608","type":"debug","z":"9aed556e.760008","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":370,"y":40,"wires":},{"id":"a8c43f28.32aed","type":"function","z":"9aed556e.760008","name":"parsing "Menu1"","func":"if (!context.count){\n context.count = 20;\n}\nparsed = parseInt(msg.payload);\nif(parsed==1){\n context.count++;\n }\n\nmsg.payload = context.count;\nreturn msg;\n","outputs":1,"noerr":0,"x":330,"y":260,"wires":[["40c35d07.249254"]]}]
I’m on my phone so can’t import your flow.
But assuming your parsing node is a function, you aren’t using the newer syntax for context values.
See
https://nodered.org/docs/writing-functions#storing-data
You can also see the Logging events part of the same page https://nodered.org/docs/writing-functions#logging-events for how to log events from within a function so you can see what your function is doing
yes thanks , but i dont really know what I should use ,Im a very beginner with node-red
Which is why I posted a link to the docs that include examples
