Is there a way to pass a string to IFTTT notifications? I’ve tried node-red-contrib-ifttt but there doesn’t seem to be an option.
I can get a notification fine but I’m guessing I need to convert the String to a JSON object and then append pairs of curly brackets to each side before making a HTTP call, or is there a better way you’d suggest?
Welcome to the forums @eerke2021
I don't use IFTTT, but the node you have linked to, can indeed make use of values.
Using a Function node, sending this to the IFTTT Node, will be utilised by IFTTT in the way it is intended.
msg.payload = {
value1 : 'Some Value',
value2 : 'Some Value',
value3 : msg.payload.someOtherValue
return msg
Read from source code : https://github.com/diegopamio/node-red-contrib-ifttt/blob/305e23cd622adeadd6635ce07c3e54afbb5e7ba3/nodes/ifttt.js#L21
It can also accept msg.payload.eventName - overriding what is setup In the node settings.
here : https://github.com/diegopamio/node-red-contrib-ifttt/blob/305e23cd622adeadd6635ce07c3e54afbb5e7ba3/nodes/ifttt.js#L26
I too haven’t had much to do with IFTTT since they stopped it being free. You used to be able to sent it 3 values surrounded by something. I think pairs of wiggly brackets. Now I think you can also send 1 JSON object. The reason I thought of using IIFTTT is that you still get 2 free “applets”. How do people round here get notifications to their phones for free? I imagine there is a way of doing in on Android with Tasker but this seemed sensible of I can figure out how to take a message and attach it to the IFTTT notification. It works fine as it is but I am limited to 2 different notifications with a free IFTTT account.
If you want to get notifications on your phone, I can only suggest what I use.
Disclaimer : There are plenty of others, and I am only stating what I use.
I use Pushover:
And a brilliant node for it:
Developed by our very own Node RED founders.
its purpose is for mobile notifications - nothing more, I use it to let me know if the home Security system has been triggered, and by what sensor
I and other also use telegram and noder-red-contrib-telegrambot just set up a private group and add a bot using botfather. You can receive messages, files, send messages to node-red, and much more.
