PCCC - Set tags from Node-RED-Dashboard
HI,
My Application is Node-RED reading tags/addresses from an AB PLC. I have it set up and working with no issues reading/writing the tags.
I would like to know if it's technically possible to setup / change the tags that the PCCC node is reading from the PLC in Node-Red Dashboard.
The idea is the end-user could navigate to x.x.x.x/ui Set the address of the tag they would like to read.
