Phoscon deConz - Raspbee II with lidl bulb
hello
i have a Phoscon deConz - Raspbee II with lidl bulb i installed the deconz node.
But can't find out how to inject a change of Brightness or ColorTemperature.
the only things working is the Toggle working - but belive more by chance
[{"id":"b35157fb.8311d8","type":"change","z":"9eb2b7eb.712208","name":"Brightness 25","rules":[{"t":"set","p":"Brightness","pt":"msg","to":"25","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":1340,"wires":[["ebfa062f.eaeed8","634650f1.e82fc"]]},{"id":"35549947.823a26","type":"inject","z":"9eb2b7eb.712208","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":1340,"wires":[["b35157fb.8311d8"]]},{"id":"ebfa062f.eaeed8","type":"deconz-output","z":"9eb2b7eb.712208","name":"bulb 01 brightness","server":"aa7a1d43.83d1b","device":"58:8e:81:ff:fe:9c:27:16-01","device_name":"Color temperature light 1 : Color temperature light","command":"bri","commandType":"deconz_cmd","payload":"payload","payloadType":"msg","transitionTime":"","x":650,"y":1360,"wires":[]},{"id":"aac55653.6a10d8","type":"change","z":"9eb2b7eb.712208","name":"Brightness 90","rules":[{"t":"set","p":"Brightness","pt":"msg","to":"90","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":1400,"wires":[["ebfa062f.eaeed8","b9ef1f64.64367"]]},{"id":"39172019.d2bbe","type":"inject","z":"9eb2b7eb.712208","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":1400,"wires":[["aac55653.6a10d8"]]},{"id":"b9ef1f64.64367","type":"debug","z":"9eb2b7eb.712208","name":"","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":630,"y":1420,"wires":[]},{"id":"634650f1.e82fc","type":"debug","z":"9eb2b7eb.712208","name":"","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":630,"y":1300,"wires":[]},{"id":"aa7a1d43.83d1b","type":"deconz-server","name":"iot11-rpi4b-gw-zigbee","ip":"10.18.42.180","port":"80","apikey":"1B99ED1E58","ws_port":"443","secure":false,"polling":"15"}]
Try this thread
They may be able to help you
Hello
i can't use my lidl.de bulb with Phoscon deConz - Raspbee II.
so my question what do you use for a working zigbee option. best would be to fit to a Raspberry pi 4!
have a nice day
vinc
This is the Solution to run RaspBee II with lidl.ch bulb CT!
it works with a inject
[{"id":"35549947.823a26","type":"inject","z":"9eb2b7eb.712208","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"255","payloadType":"num","x":210,"y":1340,"wires":[["89340561.e8f268"]]},{"id":"ebfa062f.eaeed8","type":"deconz-output","z":"9eb2b7eb.712208","name":"bulb 01 brightness","server":"aa7a1d43.83d1b","device":"58:8e:81:ff:fe:9c:27:16-01","device_name":"bulb01 : Color temperature light","command":"bri","commandType":"deconz_cmd","payload":"payload","payloadType":"msg","transitionTime":"","x":770,"y":1320,"wires":[]},{"id":"634650f1.e82fc","type":"debug","z":"9eb2b7eb.712208","name":"","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":730,"y":1260,"wires":[]},{"id":"f094f212.9166d","type":"inject","z":"9eb2b7eb.712208","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":210,"y":1260,"wires":[["89340561.e8f268"]]},{"id":"89340561.e8f268","type":"change","z":"9eb2b7eb.712208","name":"","rules":[{"t":"set","p":"bri","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":1300,"wires":[["ebfa062f.eaeed8","634650f1.e82fc"]]},{"id":"a10787b6.eca0b8","type":"comment","z":"9eb2b7eb.712208","name":"Bulb01ct lidl ","info":"object\nOn: true or false\nBrightness: 2 - 100 (0 is switched off)\nColorTemperature: 140 - 494 | kalt - warm (ornage)\n\n\nhttp://wombat3.kozo.ch/j/zigbee-list/10007","x":210,"y":1200,"wires":[]},{"id":"e6871507.111aa8","type":"inject","z":"9eb2b7eb.712208","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"995","payloadType":"num","x":210,"y":1480,"wires":[["f2c3c8b4.a10978"]]},{"id":"6f5d1891.658e88","type":"deconz-output","z":"9eb2b7eb.712208","name":"bulb 01 ColorTemperature","server":"aa7a1d43.83d1b","device":"58:8e:81:ff:fe:9c:27:16-01","device_name":"bulb01 : Color temperature light","command":"ct","commandType":"deconz_cmd","payload":"payload","payloadType":"msg","transitionTime":"","x":790,"y":1480,"wires":[]},{"id":"30231774.c29908","type":"debug","z":"9eb2b7eb.712208","name":"","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":730,"y":1420,"wires":[]},{"id":"4d4dc732.04c228","type":"inject","z":"9eb2b7eb.712208","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"5","payloadType":"num","x":210,"y":1400,"wires":[["f2c3c8b4.a10978"]]},{"id":"f2c3c8b4.a10978","type":"change","z":"9eb2b7eb.712208","name":"","rules":[{"t":"set","p":"ColorTemperature","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":460,"y":1440,"wires":[["6f5d1891.658e88","30231774.c29908"]]},{"id":"41d482c1.dd8d0c","type":"inject","z":"9eb2b7eb.712208","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"payload.On","payloadType":"global","x":250,"y":1540,"wires":[["b6a654b9.748e08"]]},{"id":"b6a654b9.748e08","type":"deconz-output","z":"9eb2b7eb.712208","name":"bulb01 command Toggle","server":"aa7a1d43.83d1b","device":"58:8e:81:ff:fe:9c:27:16-01","device_name":"Color temperature light 1 : Color temperature light","command":"toggle","commandType":"deconz_cmd","payload":"payload","payloadType":"msg","transitionTime":"","x":790,"y":1540,"wires":[]},{"id":"ada5131d.cf125","type":"inject","z":"9eb2b7eb.712208","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"125","payloadType":"num","x":210,"y":1300,"wires":[["89340561.e8f268"]]},{"id":"640e98f1.942ab8","type":"inject","z":"9eb2b7eb.712208","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"450","payloadType":"num","x":210,"y":1440,"wires":[["f2c3c8b4.a10978"]]},{"id":"aa7a1d43.83d1b","type":"deconz-server","name":"iot11-rpi4b-gw-zigbee","ip":"10.18.42.180","port":"80","apikey":"1DB8A19E85","ws_port":"443","secure":false,"polling":"15"}]
now to make it more "smart Home" it is possible to define a brightness or Temperatur on start. and in a second stage change it for the evening ?
have a nice day
vinc
