wtrk
              1
              Hi everyone.  I have a problem again. I have some device and this device connect to GPIO pins.
When I wathc this device with node red , it looks like in video, always pins showing running and stopped, pin stopped - pin running... like this.
I connected 1k Resistor to cable but still same problem.
How can I solve this problem ? Thanks for yor advance.
              Without knowing any details of the device you are using or your flow, it's hard to suggest anything.
                Colin
              3
              Are there any relevant messages in the log?  Run, in a terminal
node-red-stop
node-red-start
and copy/paste the result here.  You can use Ctrl-Shift-C to copy from the terminal. Include the start of the log so we can see versions of stuff.
