"Please add some UI nodes to your flow and redeploy."
I am running node-red on Windows 10, connected to an Arduino UNO running pyfirmata.
I just completed updating all of the node-red related software, including the new dashboard 2. In my flow I use buttons and LED's. I have replaced all of the buttons in my flow with the buttons from the new dashboard. I added the new LED 3rd party widget and replaced all of the original dashboard LED widgets. I have disabled all other flows. When I open the dashboard ( http://localhost:1880/ui ) I get the message:
Welcome to the Node-RED Dashboard
My active flow obviously has multiple ui nodes, so not sure what is causing this. The FireFox developer tools shows an error message "[HTTP/1.1 404 Not Found 2ms]. I still have the original dashboard as active, do I need to delete that? Any assistance is appreciated.
Dashboard v2 AKA @flowfuse/node-red-dashboard is at IPAddress:1880/dashboard not /ui
LOL. that was a simple fix. Not sure how I missed that. Thanks!!
You can uninstall the original node-red-dashboard if you are no longer using it.
