Please refer to the https://stackoverflow.com/questions/58290852/plotly-in-node-red
unable to get this right.
With a suggestion provided by Steve over there as well.
This is my response to SteveR ... the output in the window appears to be an array ... and is also consistent with what I have read about mustache format.
Hi Steve, I have checked the output in the debug window, its also consistent with node-red mustache doc. here is a sample output in the debug window.
var trace1 = {
x: [Wed Oct 09 2019 07:02:58 GMT-0400 (Eastern Daylight Time),Wed Oct 09 2019 07:01:19 GMT-0400 (Eastern Daylight Time),Wed Oct 09 2019 06:57:57 GMT-0400 (Eastern Daylight Time)],
y:[65.2,65.9,65.1],
I think there is a better approach that what you are trying to do... but it involves using the Angular scope to watch for a msg containing your data, which then calls the `plotly.newPlot(...) method to render the data.
I've done it in the past, but I'm having trouble finding a working example. If you can post a flows with just a couple nodes (inject data -> change or function -> ui_template) that shows what you have tried, I'll see if I can get it working...
There are some examples of using $watch here:
Thanks, I have not used Angular. But I'll dig in to find out ...
Here is the function node that gets data from MySQL node
var records = msg.payload;
var TH = { "time": , "Temperature" : , "Humidity" : };
for (var i =0; i < records.length; i++) {
var lastseen = new Date(records[i].receivedAt);
TH.Temperature.push( records[i].dataField2 );
TH.Humidity.push( records[i].dataField3 );
lastseenpayload=lastseen.getTime(); // converted to integer as I could not get date obj to work.
TH.time.push( lastseenpayload );
msg.payload = TH;
Template node
