PM2 Dashboard monitoring
For those of you using pm2 to launch and monitor your instances, this flow lets you monitor from within Node-Red
Update 04-Jul-2025
Just realised that port info is not available via the pm2 command. In my case I had set up my dashboard directory names with the port number and so was able to retrieve this from the pm2 jlist output
I've updated the flow to retrieve the port numbers from the pids of the node-red instances
So for example
ss -lptn | grep pid=357260
LISTEN 0 511 0.0.0.0:1889 0.0.0.0:* users:(("node-red",pid=357260,fd=19))
[{"id":"bfa40032e7b236f5","type":"group","z":"d63da7d39b03706f","name":"Node-Red","style":{"fill":"#7fb7df","label":true,"color":"#000000"},"nodes":["5c732e4feb3baed0","a08d268203b4a005","96c575b95962a468","a30fcfc64ebdd450","18220c4ca4e6f003","6d2ef10283fecb0f","63f97a4ad7c4c9e8","8fec360a293987af"],"x":34,"y":739,"w":952,"h":149.5},{"id":"5c732e4feb3baed0","type":"exec","z":"d63da7d39b03706f","g":"bfa40032e7b236f5","command":"/usr/local/bin/pm2 jlist","addpay":"","append":"","useSpawn":"false","timer":"","winHide":false,"oldrc":false,"name":"Node Info","x":200,"y":800,"wires":[["a30fcfc64ebdd450"],[],[]]},{"id":"a08d268203b4a005","type":"inject","z":"d63da7d39b03706f","g":"bfa40032e7b236f5","name":"","props":[{"p":"topic","vt":"str"}],"repeat":"300","crontab":"","once":false,"onceDelay":0.1,"topic":"OS Info","x":95,"y":800,"wires":[["5c732e4feb3baed0"]],"l":false},{"id":"96c575b95962a468","type":"function","z":"d63da7d39b03706f","g":"bfa40032e7b236f5","name":"Map","func":"const dashboards=msg.payload\nlet props = [];\nconst numberPattern = /\\d{4}/g\n//payload[1].pm2_env.args[1]\n\ndashboards.forEach(dashboard => {\n    const d1 = new Date(dashboard.pm2_env.pm_uptime)\n    const d2 = new Date();\n    const diff = Math.abs(d2.getTime() - d1.getTime())\n    const updays = Math.floor(diff / (1000 * 60 * 60 * 24))\n    const name = dashboard.name.toUpperCase()\n    //const pid = dashboard.pm2_env.args[1]\n    //node.warn(path)\n    //const port =path.match(numberPattern)[0]\n    const mem = (dashboard.monit.memory/ (1024 * 1024)).toFixed(1) + \" MB\"\n    const status = dashboard.pm2_env.status=='online' ?'lawngreen':'orange'\n    const handles =dashboard.pm2_env.axm_monitor[\"Active handles\"]\n    const requests =dashboard.pm2_env.axm_monitor[\"Active requests\"]\n\n\n    let arr = { \n        \"PMID\": dashboard.pm_id ,\n        \"NAME\": name,\n        \"PORT\": \"\",\n        \"PID\": dashboard.pid,\n        \"UPTIME\": updays+'D',\n        \"STATUS\": status,\n        \"CPU\": dashboard.monit.cpu +'%',\n        \"HANDLES\": handles.value,\n        \"REQUESTS\": requests.value,\n        \"MEMORY\": mem,\n        };\n    props.push(arr);\n})\n\nmsg.payload=props\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":780,"wires":[["6d2ef10283fecb0f"]]},{"id":"a30fcfc64ebdd450","type":"json","z":"d63da7d39b03706f","g":"bfa40032e7b236f5","name":"","property":"payload","action":"","pretty":false,"x":370,"y":780,"wires":[["96c575b95962a468"]]},{"id":"18220c4ca4e6f003","type":"ui-table","z":"d63da7d39b03706f","g":"bfa40032e7b236f5","group":"1c54b30d7d8e7c7b","name":"Node-RED","label":"DASHBOARD INSTANCES","order":3,"width":0,"height":0,"maxrows":0,"passthru":false,"autocols":false,"showSearch":false,"deselect":true,"selectionType":"click","columns":[{"title":"PM ID","key":"PMID","keyType":"key","type":"text","width":"","align":"start"},{"title":"NAME","key":"NAME","keyType":"key","type":"text","width":"","align":"start"},{"title":"PORT","key":"PORT","keyType":"key","type":"text","width":"","align":"start"},{"title":"UPTIME","key":"UPTIME","keyType":"key","type":"text","width":"","align":"start"},{"title":"STATUS","key":"STATUS","keyType":"key","type":"color","width":"","align":"start"},{"title":"HANDLES","key":"HANDLES","keyType":"key","type":"text","width":"","align":"start"},{"title":"CPU","key":"CPU","keyType":"key","type":"progress","width":"","align":"start"},{"title":"MEMORY","key":"MEMORY","keyType":"key","type":"text","width":"","align":"start"}],"mobileBreakpoint":"sm","mobileBreakpointType":"defaults","action":"replace","x":890,"y":840,"wires":[[]]},{"id":"6d2ef10283fecb0f","type":"function","z":"d63da7d39b03706f","g":"bfa40032e7b236f5","name":"cmd","func":"const instances=msg.payload\nmsg.instances=instances\nlet cmd=''\ninstances.forEach(instance => {\n    cmd += `ss -lptn | grep pid=${instance.PID} && `\n    \n});\n\nmsg.payload=cmd.slice(0,-3)\nreturn msg;\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":430,"y":840,"wires":[["63f97a4ad7c4c9e8"]]},{"id":"63f97a4ad7c4c9e8","type":"exec","z":"d63da7d39b03706f","g":"bfa40032e7b236f5","command":"","addpay":"payload","append":"","useSpawn":"false","timer":"","winHide":false,"oldrc":false,"name":"Get Port","x":580,"y":840,"wires":[["8fec360a293987af"],[],[]]},{"id":"8fec360a293987af","type":"function","z":"d63da7d39b03706f","g":"bfa40032e7b236f5","name":"Port","func":"const ports = msg.payload.split('\\n')\nlet instances =msg.instances\nmsg.instances= null\nlet i=0\n\nports.forEach(p => {\n    if(p !=\"\"){\n        const port = p.substr(54, 4)\n        instances[i].PORT = port\n        i++\n    }\n        \n});\nmsg.payload=instances\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":840,"wires":[["18220c4ca4e6f003"]]},{"id":"1c54b30d7d8e7c7b","type":"ui-group","name":"Dashboard","page":"40b1bea1d5488e9d","width":"12","height":1,"order":4,"showTitle":false,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"40b1bea1d5488e9d","type":"ui-page","name":"System Status","ui":"4740393b964cb7af","path":"/system","icon":"mdi-cog","layout":"tabs","theme":"11edfaf96d0baec1","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":16,"className":"","visible":"true","disabled":"false"},{"id":"4740393b964cb7af","type":"ui-base","name":"Tiger","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control","ui-dropdown","ui-chart","ui-gauge","ui-button","ui-template","ui-text","ui-table","ui-form"],"showPathInSidebar":false,"headerContent":"page","navigationStyle":"fixed","titleBarStyle":"hidden","showReconnectNotification":true,"notificationDisplayTime":"1","showDisconnectNotification":true},{"id":"11edfaf96d0baec1","type":"ui-theme","name":"Dark1","colors":{"surface":"#424242","primary":"#0094ce","bgPage":"#424242","groupBg":"#424242","groupOutline":"#424242"},"sizes":{"density":"default","pagePadding":"2px","groupGap":"6px","groupBorderRadius":"4px","widgetGap":"10px"}}]
Page
Very Nice.
I use NSSM to run Node-red as a windows service. Any possibility of similar application possible. if you could direct me to the right path, i will try to pursue.
EDIT: sc query state= all seems to give me some info, will follow from there.
Don't know much about nssm but possibly powershell will give you what you want
Add whatever columns are available to the select part. then modify the map function to suit
I'm pretty sure you can install pm2 on windows as well
Get-WmiObject win32_service | ?{$_.PathName -like '*nssm*'} | select Name, DisplayName, State, PathName | ConvertTo-Json
or as you mentioned sc although I think the sc output will just be one entry in json and very hard to parse
sc.exe query type= service| ConvertTo-Json
I run PM2 on Windows - but if already using nssm, it is rather redundant.
Brave's Leo AI gave me this for more detail (not tried it):
$Details = @()
$AllRunningServices = Get-CimInstance -class win32_service | Where-Object {$_.State -eq 'Running'} | Select-Object ProcessId, Name
foreach($procid in $AllRunningServices) {
    $Details += Get-Process | Where-Object {$_.Id -eq $procid.ProcessId} | Select-Object ProcessName, Id, CPU, @{Name = "serviceName"; Expression={$procid.Name}}
$Details | Sort-Object -Property CPU -Descending | ft
Get-process gives you lots of detail about your running services.
Does this mean I have to switch to PM2?
I am happy with NSSM and till today have no issues running 5 different instances of NR as windows services.
No, NSSM is perfectly fine. Julian was stating installing and setting up PM2 is redundant as you have a working solution.
Not at all, you can get everything shown in the PM2 example using PowerShell and more besides. If nssm is working for you, it is fine. I really meant that PM2 is redundant for you, not nssm. :blush:
I use PM2 for convenience as I don't always have Node-RED running on my Windows desktop. My "live" version is on a separate server. Though recently, I have changed things so that Node-RED (via PM2) runs anyway after I log into my user account.
Hmmm. Need to improve my English comprehension.
:blush: No worries at all. It is good for us English speakers to be reminded that not everyone has our language as their first.
Original flow updated to pull port information which is not available with pm2 commands
Liking the new visual renderer for flows :heart:
This flow did not go quite as smooth as your last system stats flow @gerrybartley
Vanalla install of 11 Node-RED's on Linux, using PM2 to manage.
Adding extra debugs, I can see the usual slug of JSON data come back from the command, but the map node returns: TypeError: Cannot read properties of null (reading '0')
I can't follow the code in that node, so will leave it at that. Just an FYI incase others try it.
I forgot to delete the old flow when I updated the new flow so there were 2 flows. The old one is now deleted. I wonder did you download the old flow. In my process.json file for pm2 the directory for each instance is passed as an argument. The old flow read this argument so worked for me. However may cause that error you encountered. I think if you download the flow again it should work .If not I'm sure we can work out what's happening
This should be the code you see in the map function
let props = [];
const numberPattern = /\d{4}/g
    //node.warn(path)
    const mem = (dashboard.monit.memory/ (1024 * 1024)).toFixed(1) + " MB"
    const handles =dashboard.pm2_env.axm_monitor["Active handles"]
    const requests =dashboard.pm2_env.axm_monitor["Active requests"]
    let arr = {
        "PMID": dashboard.pm_id ,
        "NAME": name,
        "PORT": "",
        "PID": dashboard.pid,
        "UPTIME": updays+'D',
        "STATUS": status,
        "CPU": dashboard.monit.cpu +'%',
        "HANDLES": handles.value,
        "REQUESTS": requests.value,
        "MEMORY": mem,
    props.push(arr);
msg.payload=props
If you can post your pm2 jlist output suitably sanitized even better
