I am trying the following customization for the PolarArea chart and only the legend part works. Can anyone review the following and tell me why it doesn't work?
msg.ui_control = {
type: 'polarArea',
options: {
legend: {
display: true,
position: 'top'
scales:{
r:{
grid: {
color:'white'
ticks:{
display: false
pointLabels:{
display: false
delete msg.payload
return msg
The chartjs in use is v2.3 something but you have probably found documents for newer stuff.
To get it working use scale property as described here: Styling · Chart.js documentation
msg.ui_control = {
options: {
legend: {
display: true,
position: 'top'
scale:{
display:true,
gridLines: {
color: "#00FF00"
ticks: {
display: false
delete msg.payload
return msg
Thank you!
How would you implement the background color and hoverBackgroundColor element?
Don't understand the question.
Similar to gridlines, I want to modify the background colors of the regions and background color when hovering over them.
Those are properties of the dataset. You cannot reach them via ui_control message. To modify them, you'll need to create the chart from scratch using the ui_template node. (Or template node feeding ui_template).
You can find many examples here in forum where chart is created that way but I'm afraid none of them will have Polar Area Chart. But anyway - it is basically same just you'll need to follow documents to create needed structure for polar chart.
It takes kind of intermediate understanding of front-end codding.
