Port in Use NodeRed Error
Welcome to Node-RED
16 Jul 13:26:26 - [info] Node-RED version: v3.0.0
16 Jul 13:26:26 - [info] Node.js  version: v16.16.0
16 Jul 13:26:26 - [info] Linux 5.15.0-41-generic x64 LE
16 Jul 13:26:27 - [info] Loading palette nodes
16 Jul 13:26:28 - [info] Dashboard version 3.1.7 started at /ui
16 Jul 13:26:28 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
16 Jul 13:26:28 - [info] Settings file  : /home/diego/.node-red/settings.js
16 Jul 13:26:28 - [info] Context store  : 'default' [module=memory]
16 Jul 13:26:28 - [info] User directory : /home/diego/.node-red
16 Jul 13:26:28 - [warn] Projects disabled : editorTheme.projects.enabled=false
16 Jul 13:26:28 - [info] Flows file     : /home/diego/.node-red/flows.json
16 Jul 13:26:28 - [warn] Encrypted credentials not found
16 Jul 13:26:28 - [error] Uncaught Exception:
16 Jul 13:26:28 - [error] Error: listen EADDRINUSE: address already in use 192.168.1.124:1880
    at Server.setupListenHandle [as _listen2] (node:net:1372:16)
    at listenInCluster (node:net:1420:12)
    at doListen (node:net:1559:7)
    at processTicksAndRejections (node:internal/process/task_queues:84:21)
diego@diego-HP-G42-Notebook-PC:~$ sudo lsof -i
COMMAND     PID            USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
systemd-r   566 systemd-resolve   12u  IPv4  24122      0t0  UDP localhost:domain
systemd-r   566 systemd-resolve   13u  IPv4  24123      0t0  TCP localhost:domain (LISTEN)
avahi-dae   598           avahi   12u  IPv4  28745      0t0  UDP *:mdns
avahi-dae   598           avahi   13u  IPv6  28746      0t0  UDP *:mdns
avahi-dae   598           avahi   14u  IPv4  28747      0t0  UDP *:38623
avahi-dae   598           avahi   15u  IPv6  28748      0t0  UDP *:39039
cupsd       600            root    6u  IPv6  25269      0t0  TCP ip6-localhost:ipp (LISTEN)
cupsd       600            root    7u  IPv4  25270      0t0  TCP localhost:ipp (LISTEN)
NetworkMa   602            root   23u  IPv4 298742      0t0  UDP diego-HP-G42-Notebook-PC:bootpc->Cisco06007:bootps
cups-brow   693            root    7u  IPv4  26578      0t0  UDP *:631
gvfsd-smb 17917           diego   10u  IPv4 163401      0t0  TCP diego-HP-G42-Notebook-PC:42582->Cisco06007:netbios-ssn (ESTABLISHED)
firefox   22817           diego   38u  IPv4 426685      0t0  TCP diego-HP-G42-Notebook-PC:43890->upload-lb.eqiad.wikimedia.org:https (ESTABLISHED)
firefox   22817           diego   61u  IPv4 301105      0t0  TCP diego-HP-G42-Notebook-PC:58762->ec2-34-214-236-46.us-west-2.compute.amazonaws.com:https (ESTABLISHED)
firefox   22817           diego  114u  IPv4 437500      0t0  TCP diego-HP-G42-Notebook-PC:60920->184.105.176.47:https (ESTABLISHED)
firefox   22817           diego  130u  IPv4 314637      0t0  TCP diego-HP-G42-Notebook-PC:52102->whatsapp-cdn-shv-02-mia3.fbcdn.net:https (ESTABLISHED)
firefox   22817           diego  159u  IPv4 432217      0t0  TCP diego-HP-G42-Notebook-PC:47660->151.101.4.193:https (ESTABLISHED)
firefox   22817           diego  203u  IPv4 433201      0t0  TCP diego-HP-G42-Notebook-PC:53212->bog02s14-in-f2.1e100.net:https (ESTABLISHED)
firefox   22817           diego  207u  IPv4 432230      0t0  TCP diego-HP-G42-Notebook-PC:43360->bog02s15-in-f1.1e100.net:https (ESTABLISHED)
firefox   22817           diego  211u  IPv4 433162      0t0  TCP diego-HP-G42-Notebook-PC:43364->bog02s15-in-f1.1e100.net:https (ESTABLISHED)
firefox   22817           diego  217u  IPv4 433218      0t0  TCP diego-HP-G42-Notebook-PC:47532->bog02s17-in-f2.1e100.net:https (ESTABLISHED)
firefox   22817           diego  231u  IPv4 432198      0t0  TCP diego-HP-G42-Notebook-PC:33780->bog02s16-in-f2.1e100.net:https (ESTABLISHED)
firefox   22817           diego  238u  IPv4 430071      0t0  TCP diego-HP-G42-Notebook-PC:40484->151.101.1.69:https (ESTABLISHED)
firefox   22817           diego  243u  IPv4 430526      0t0  TCP diego-HP-G42-Notebook-PC:45444->xx-fbcdn-shv-02-mia3.fbcdn.net:https (ESTABLISHED)
firefox   22817           diego  244u  IPv4 433164      0t0  TCP diego-HP-G42-Notebook-PC:58380->bog02s16-in-f1.1e100.net:https (ESTABLISHED)
firefox   22817           diego  254u  IPv4 433205      0t0  TCP diego-HP-G42-Notebook-PC:43262->vn-in-f156.1e100.net:https (ESTABLISHED)
node-red  39548           diego   18u  IPv4 425868      0t0  TCP diego-HP-G42-Notebook-PC:1880->ESP-3FDA2B:50989 (CLOSE_WAIT)
node-red  39548           diego   19u  IPv4 426270      0t0  TCP diego-HP-G42-Notebook-PC:1880 (LISTEN)
Idk how to solve it, everything is fine when ESP is not sending data but when it stats to do it the server overloads
We have been through that error a number of times. It is because node red is already running. If it is hogging the processor then after node-red-stop it may be a couple of minutes before node red stops. If it won't stop then reboot.
Start it in safe mode and break the flow (remove a wire) early in the flow that the ESP runs. Deploy and make sure the server is not overloaded. Join that wire back and break it a bit further on and deploy again. Keep doing it till you find why it is hanging.
idk if this is the issue
diego@diego-HP-G42-Notebook-PC:~$ ss --tcp state CLOSE-WAIT --kill
SOCK_DESTROY answers: Operation not permitted
Recv-Q            Send-Q                         Local Address:Port                          Peer Address:Port             Process
310               0                              192.168.1.124:1880                         192.168.1.122:50491
310               0                              192.168.1.124:1880                         192.168.1.122:62909
310               0                              192.168.1.124:1880                         192.168.1.122:55467
310               0                              192.168.1.124:1880                         192.168.1.122:57083
310               0                              192.168.1.124:1880                         192.168.1.122:55711
310               0                              192.168.1.124:1880                         192.168.1.122:61882
310               0                              192.168.1.124:1880                         192.168.1.122:63121
310               0                              192.168.1.124:1880                         192.168.1.122:54613
310               0                              192.168.1.124:1880                         192.168.1.122:61514
310               0                              192.168.1.124:1880                         192.168.1.122:65406
310               0                              192.168.1.124:1880                         192.168.1.122:52483
310               0                              192.168.1.124:1880                         192.168.1.122:63080
310               0                              192.168.1.124:1880                         192.168.1.122:59107
310               0                              192.168.1.124:1880                         192.168.1.122:64907
310               0                              192.168.1.124:1880                         192.168.1.122:64396
310               0                              192.168.1.124:1880                         192.168.1.122:63942
310               0                              192.168.1.124:1880                         192.168.1.122:55218
310               0                              192.168.1.124:1880                         192.168.1.122:55901
310               0                              192.168.1.124:1880                         192.168.1.122:52642
310               0                              192.168.1.124:1880                         192.168.1.122:63218
310               0                              192.168.1.124:1880                         192.168.1.122:59091
310               0                              192.168.1.124:1880                         192.168.1.122:63229
310               0                              192.168.1.124:1880                         192.168.1.122:61705
310               0                              192.168.1.124:1880                         192.168.1.122:64180
310               0                              192.168.1.124:1880                         192.168.1.122:59068
310               0                              192.168.1.124:1880                         192.168.1.122:60764
310               0                              192.168.1.124:1880                         192.168.1.122:55357
310               0                              192.168.1.124:1880                         192.168.1.122:50586
310               0                              192.168.1.124:1880                         192.168.1.122:65387
310               0                              192.168.1.124:1880                         192.168.1.122:55079
310               0                              192.168.1.124:1880                         192.168.1.122:61878
310               0                              192.168.1.124:1880                         192.168.1.122:58084
310               0                              192.168.1.124:1880                         192.168.1.122:51888
310               0                              192.168.1.124:1880                         192.168.1.122:61546
310               0                              192.168.1.124:1880                         192.168.1.122:56403
310               0                              192.168.1.124:1880                         192.168.1.122:63441
310               0                              192.168.1.124:1880                         192.168.1.122:61145
310               0                              192.168.1.124:1880                         192.168.1.122:55469
310               0                              192.168.1.124:1880                         192.168.1.122:50790
310               0                              192.168.1.124:1880                         192.168.1.122:52607
310               0                              192.168.1.124:1880                         192.168.1.122:50956
310               0                              192.168.1.124:1880                         192.168.1.122:60882
310               0                              192.168.1.124:1880                         192.168.1.122:54739
310               0                              192.168.1.124:1880                         192.168.1.122:51983
310               0                              192.168.1.124:1880                         192.168.1.122:57523
1                 0                              192.168.1.124:1880                         192.168.1.122:52365
Remember that once node-red hangs up everything will run slow, including the networking.
How did you get on with the suggestions in my previous post?
That is an understatement... depending on the device, it can lock things up so well, that it is struggle to just get NR stopped. Have done a few times over the years!
There is a specific socket mode you can use to get the Linux OS to try and I stress try to re-use ports that are hung or less than gracefully abandoned, but this is tricky even in the best of circumstances.
https://man7.org/linux/man-pages/man7/socket.7.html
Reference: " Linux will allow port reuse only with the SO_REUSEADDR option when this option was set both in the previous program that performed a bind(2) to the port and in the program that wants to reuse the port."
But there maybe not be a straight-forward way to leverage this feature within NR, have not had chance to dig into it as yet. I had some issues with using UDP port 9 recently when I wrote a flow to monitor WOL packet deployment, so was going to get back to using SO_REUSEADDR at some point. Used it all the time when I was writing C based socket based solutions.
