PostgreSQL node Queue value
Hello guys, how to access value of Queue of postgres node?
Or maybe a better question, how to batch import the data into postgres in nodered (array of objects) ?
Thanks!
Have you tried the status node, it may pick it up.
Thanks for advice,
I solved the problem via going into:
/home/ubuntu/.node-red/node_modules/node-red-contrib-postgresql
Open file postgresql.js
and before the line
send(msg);
I added:
msg.queue = nbQueue;
Now every postgresSQL gives desired info in msg.queue.
Or, instead of hacking the code (which you will lose if the node is ever updated), you could use a status node (like @E1cid suggested)?
Better still, you could raise a pull request against the repository so that everyone benefits?
