Postgresql with nodered - Error: connect ECONNREFUSED 192.168.0.27:5432
Hi!
I am trying to connect PostgreSQL with nodered, but:
Nodered is inside a virtual machine (ip: 192.168.0.28)
PostgreSQL isinside virtual machine (192.168.0.27)
db_instalacion
user_instalacion
port:5432
Between the virtual machines the communication is correct, since I can ping without problem
What is happening?
Have you etup PostgreSQL to allow Remote Connections?
Tons of info on the net e.g. "How To Configure PostgreSQL to Allow Remote Connections – TecAdmin" How To Configure PostgreSQL to Allow Remote Connections – TecAdmin
Also check (from the node-red machine) that port 5432 is open on the db machine. Using nmap for example.
Thanks! I have follow link steps. In the first time i had a problem because i couldn´t login in pgadmin after the pg_hba.conf file change. After i saw a comment thas says: use "host all all ::0/0 md5" and not "host all all :/0 md5" and the connection was ok! Thanks!
