At the beginning of this discussion, I asked
If no name defined on debug node and only node status is selected - default the node label to "status"
If the gray dot is there under that condition (which its not in the current github codebase) then I'd be very happy
My attempt No 17 a couple of posts ago was an amended request which I'd glady drop if my first one could be achieved
Just to clarify - I don't mean defaulting the node label to status - I'd just be happy to have any visual solution to being able to tell that only node status is selected
OK - final thoughts before we close this down...
If status mode on - show grey ring at start - and grey dot as soon as a message arrives (and from then on)
If status mode off - don't show anything
If to sidebar on - show button on right (as per today)
If to sidebar off - hide button on right (as it would have no effect) - Not yet implemented - would be next release
That sounds a good idea
I think we are ALL agreed on that one
Of course
Where do you want the case of Kruger sending?
PS You might want to do a bit of ORing with console on as well as sidebar on - I don't use it myself but the ones that do would probably want the button available if console on was selected
the button has NEVER affected the console output - so not an issue.
They are now all independent.
