Prepare array of JSON-Objects with jsonata through change-node for node-red-dashboard multiline-chart
trying to transform an array of JSON-objects for dashboard-chart-node, I have problems with jsonata-code.
Probably it's not hard to solve, thank you for helping!
The third graph ('CALC') is already prepared properly, the two others ('DATEN.humidy' /'DATEN.temperature') don't work.
Underneath input-/output-msg.payload and the jsonata-code for the change-node. The problematic part is written bold, with a comment at the end of the line.
Input msg.payload:
    "DATUM": 1640024797000,
    "DATEN": {
      "temperature": 14.28,
      "humidity": 58
    "CALC": 29
    "DATUM": 1640024787000,
    "DATEN": {
      "temperature": 14.33,
      "humidity": 59
    "CALC": 29
    "DATUM": 1640023606000,
    "DATEN": {
      "temperature": 14.24,
      "humidity": 62
    "CALC": 30
change node:
set msg.payload to jsonata:
  $series := [
    { "field_Y": **"DATEN.humidity"**,  "field_X": "DATUM", "label": "relative Luftfeuchtigkeit in %", "header": "topic"},  /* "DATEN.temperature" is not correct, how could it be written to properly display the temperature?*/
    { "field_Y": **"DATEN"**,  "field_X": "DATUM", "label": "Temperatur in °C", "header": "topic"},
    { "field_Y": "CALC",    "field_X": "DATUM", "label": "Enthalpie in kj/kg Luft", "header": "topic"}
      "series": $series.label,
      "data": $series.[
          $yaxis := $.field_Y;
          $xaxis := $.field_X;
          $$.payload.{
            "x": $lookup($, $xaxis),
            "y": $lookup($, $yaxis)
payload output:
    "series": [
      "Temperatur in °C",
    "data": [
          "x": 1640024797000
          "x": 1640024787000
          "x": 1640023606000
          "x": 1640024797000,
          "y": {
            "humidity": 58
          "x": 1640024787000,
          "y": {
            "humidity": 59
          "x": 1640023606000,
          "y": {
            "humidity": 62
          "x": 1640024797000,
          "y": 29
          "x": 1640024787000,
          "y": 29
          "x": 1640023606000,
          "y": 30
The $eval() function should work.
"y": $eval("$." & $yaxis)
To expand on the previous answer -- the $lookup function will only work for 1 level, which is why DATEN.xxx cannot be used directly.
On the other hand, $eval(...) can take any expression, including the dotted notation you need:
      "data": $series@$s.[
        $$.payload.{
          "x": $eval($s.field_X),
          "y": $eval($s.field_Y)
FYI - you can also use the Context Variable binding syntax @$var to assign each series definition to a variable name, to avoid the intermediate variables for $xaxis and $yaxis.
Works perfectly, thank you!
  $series := [
    { "field_Y": "DATEN.humidity",  "field_X": "DATUM", "label": "relative Luftfeuchtigkeit in %", "header": "topic"},
    { "field_Y": "DATEN.temperature",  "field_X": "DATUM", "label": "Temperatur in °C", "header": "topic"},
      "data": $series.[
          $$.payload.{
            "x": $eval("$." & $xaxis),
It would be nice to shorten the code, but if I copy that code into mine the result is just one array with the objects of the three graphs.
output msg.payload:
  "series": [
    "Temperatur in °C",
  "data": [
      "x": 1640075700000,
      "y": 60
      "x": 1640075670000,
      "y": 60
      "x": 1640075660000,
      "y": 60
      "x": 1640075700000,
      "y": 10.1
      "x": 1640075670000,
      "y": 9.99
      "x": 1640075660000,
      "y": 9.99
      "x": 1640075700000,
      "y": 22
      "x": 1640075670000,
      "y": 21
      "x": 1640075660000,
      "y": 21
Yep, looks like I dropped one level of square brackets...
The shortened version works perfectly now, thank you!
jsonata-code for change-node:
  $series := [
    { "field_Y": "CALC",    "field_X": "DATUM", "label": "Enthalpie in kJ/kg Luft", "header": "topic"}
      "data": $series@$s.[[
        $$.payload.{
