I have Node-RED running on Code Engine in the IBM Cloud, based on the Node-RED Starter Kit. Even though I configured user user credentials during the setup, anyone can visit the editor and view the logs, which I would like to prevent. There is documentation on the NODE_RED_GUEST_USER environment variable, but I haven't been able to set it effectively to false, to prevent anonymous read access. For example, on the Code Engine Application Environment variables tab I've set NODE_RED_GUEST_USER as literal false, with no effect.
Any idea on what can be done in this hosting environment to prevent anonymous read access to the editor UI?
