Since a change which causes a "connection to server lost" after changings in some nodes i am not able to start node-red any more.
> 21 Jul 18:47:33 - [info] [fritzbox-callmonitor:7665017.2302b] Connecting to fritzbox...
21 Jul 18:47:34 - [info] [remote-access:9e516375043536c8] Server: nodered04.remote-red.com InstanceHash: ao9tjr1ljf8yrj1wcggx5hxcp6gi1n7ymugrymcvxkepb7x0qyk3oz8ivy49n2kp
21 Jul 18:47:34 - [info] BooleanLogicUltimate: Will create 2 dummy (false) values
21 Jul 18:47:35 - [info] [cul-in:ecb2279126389492] Going to add:
21 Jul 18:47:35 - [info] [cul-controller:b83a202cb5fb4c18] Adding node "ecb2279126389492" to controller "".
21 Jul 18:47:35 - [info] [cul-controller:b83a202cb5fb4c18] Connecting to cul device at /dev/ttyAMA0@9600 in mode[SlowRF]
21 Jul 18:47:35 - [info] [cul-controller:b83a202cb5fb4c18] serialport:/dev/ttyAMA0
21 Jul 18:47:35 - [info] [cul-controller:b83a202cb5fb4c18] baudrate:9600
21 Jul 18:47:35 - [info] [cul-controller:b83a202cb5fb4c18] mode:SlowRF
21 Jul 18:47:35 - [info] [cul-controller:b83a202cb5fb4c18] parse:true
21 Jul 18:47:35 - [info] [cul-controller:b83a202cb5fb4c18] init:true
21 Jul 18:47:35 - [info] [cul-controller:b83a202cb5fb4c18] coc:false
21 Jul 18:47:35 - [info] [cul-controller:b83a202cb5fb4c18] scc:false
21 Jul 18:47:35 - [info] [cul-controller:b83a202cb5fb4c18] rssi:true
(node:1489) [DEP0170] DeprecationWarning: The URL http://fe80::9ec7:a6ff:fee1:134a:49000/igddesc.xml is invalid. Future versions of Node.js will throw an error.
(Use `node --trace-deprecation ...` to show where the warning was created)
21 Jul 18:47:35 - [red] Uncaught Exception:
21 Jul 18:47:35 - [error] TypeError: botCommandsForLanguage.filter is not a function
at TelegramBotNode.setMyCommands (/home/pi/.node-red/node_modules/node-red-contrib-telegrambot/telegrambot/99-telegrambot.js:538:70)
at TelegramBotNode.onStarted (/home/pi/.node-red/node_modules/node-red-contrib-telegrambot/telegrambot/99-telegrambot.js:567:18)
at EventEmitter.emit (node:events:519:28)
at Object.start [as startFlows] (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/index.js:409:12)
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Failed with result 'exit-code'.
nodered.service: Consumed 16.875s CPU time.
Is the error a problem in the telegram node? Is it possible to deactivate such nodes by hand?
