Problem to format color in dropdown ui node
in edit text node there is a simple way to change color to a specific edit text box using following syntax for example in label field
<font color= white > Identifiant </font>
or following syntaxe for value format field
<font color= white > {{msg.payload}} </font>
for dropdown ui we area ble to do the same thing with label but i don't find the way to format value
it strange to mr so perhaps i miss something somewhere . Is there a solution for this ? why in dropdown Ui we don't have format value field ?
Use CSS in a UI-Template node.
For example
md-option .md-text, md-select-value .md-text {
color: green;
thanks it works fine !
