maybe its not hardware or heat related .. maybe just the possibility that you are making to many requests.
The following from the SMA website .. Modbus FAQ
Interesting - thank you
Is it possible that NR keeps the connection open after the use of modbus- getter?
If YES can I close it somehow?
Very good question .. i was wondering about that also ..
Its not so much related to Node-red but depends on the Modbus nodes and the modbus-serial library they use .. how well they handle open connections .. and if its already open, not to open another one .. complicated stuff .. i dont know the answer to that.
Short update: I reduced the readings via ModBus/TCP to 2 every 5 minutes - so far it is running fine now.
