I cannot insert the ui-led library, I have tried to uninstall it and reinstall it but the LED appears disabled. Ate. Estuardo
Which versions of node.is, node-red and dashboard are you using ?
Node js v13.1.0 / Node red v1.0.3 / node-red-contrib-ui-led 0.3.1
We've never tested Node13 yet - we recommend Node12 LTS.
I tried the previous version but the solution did not work, was to copy the .node-ned folder located in C:\Users\PC from another machine and it was fixed.
