Programmatically disable a node?
Is it possible to programmatically disable a node? Scenario is I have multiple load cells connected to a Phidgets hardware interface. In node-red each loadcell has its own input node. Due to the data intervals that one of the load cells needs, I have found it only reads properly if the other input nodes are manually disabled. Not feasible to do that live. What I want is when I am on UI tab 1/sensor 1, the other load cell nodes are disabled. When I click on UI tab 2/sensor 2, it enables that node, and disables the others. etc. Only need to see one load cell values at a time. But the only way I see this being possible is if there is a way to programmatically disable a node, which I have not found.
Use simple gate and ui control.
Can be made simpler, but this flow i think will explain working better.
replace input-1,2,3 with your load cell input, and using ui-control you can replace open-1,2,3 inject nodes or use buttons in dashboard to trigger relevant inputs.
[{"id":"0e7bbcca5061c4d8","type":"group","z":"633f7c1cbaea0e47","name":"LoadCell Group","style":{"stroke":"#001f60","fill":"#ffffbf","label":true,"color":"#92d04f"},"nodes":["c17a897d3f6a4dd4","4245f50364641925","08f68ebffe65aaaa","d9a9a80634a7c83d","735e1f9e8853a45b","fa57b34eb6948670","04e057d523dc7a27","122909071aa09761","8a5ec0370ac8735c","4f91186f0f73acbc","2a961ffb7bbd2b32","70ab713a4f74dd45","d653903dec8d6d52","f777b54c43dbc459","167d354ee679eea5","d8a157e1a366a049","39f9b21a2cfbda49","929eba1173f83f56","2fd0920ae195a08c","be96e999b41ef9c3","16da3d6470fbf5b3","95200c04d784565d","5e82a87ce52001cb","f13a2d378842e397","2bbdbdbb1ab1cc2c","0ff757f5fac6e9e0","d246a87d09d95dd4","ac3ee171da59ee6c","673b7d090613085c"],"x":93,"y":130,"w":1213,"h":482},{"id":"c17a897d3f6a4dd4","type":"gate","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Load_Cell_1","controlTopic":"control","defaultState":"open","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":false,"storeName":"memory","x":910,"y":360,"wires":[["735e1f9e8853a45b"]]},{"id":"4245f50364641925","type":"gate","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Load_Cell_2","controlTopic":"control","defaultState":"closed","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":false,"storeName":"memory","x":910,"y":460,"wires":[["735e1f9e8853a45b"]]},{"id":"08f68ebffe65aaaa","type":"gate","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Load_Cell_3","controlTopic":"control","defaultState":"closed","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":false,"storeName":"memory","x":910,"y":560,"wires":[["735e1f9e8853a45b"]]},{"id":"d9a9a80634a7c83d","type":"inject","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Input-1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1","crontab":"","once":true,"onceDelay":0.1,"topic":"LC-1","payload":"$ceil($random()*100)","payloadType":"jsonata","x":660,"y":360,"wires":[["c17a897d3f6a4dd4"]]},{"id":"735e1f9e8853a45b","type":"debug","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"debug 3074","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"topic&\"-\"&payload","statusType":"jsonata","x":1190,"y":460,"wires":[]},{"id":"fa57b34eb6948670","type":"inject","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Input-2","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1","crontab":"","once":true,"onceDelay":"0.3","topic":"LC-2","payload":"$ceil($random()*100)","payloadType":"jsonata","x":660,"y":460,"wires":[["4245f50364641925"]]},{"id":"04e057d523dc7a27","type":"inject","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Input-3","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1","crontab":"","once":true,"onceDelay":"0.5","topic":"LC-3","payload":"$ceil($random()*100)","payloadType":"jsonata","x":660,"y":560,"wires":[["08f68ebffe65aaaa"]]},{"id":"122909071aa09761","type":"change","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Open","rules":[{"t":"set","p":"payload","pt":"msg","to":"open","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":334,"y":351,"wires":[["4f91186f0f73acbc","167d354ee679eea5"]],"icon":"font-awesome/fa-play","l":false},{"id":"8a5ec0370ac8735c","type":"inject","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Open-1","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":189,"y":351,"wires":[["122909071aa09761"]]},{"id":"4f91186f0f73acbc","type":"change","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Close","rules":[{"t":"set","p":"payload","pt":"msg","to":"close","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":334,"y":311,"wires":[["5e82a87ce52001cb","95200c04d784565d"]],"icon":"font-awesome/fa-pause","l":false},{"id":"2a961ffb7bbd2b32","type":"inject","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Close All","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":199,"y":171,"wires":[["70ab713a4f74dd45"]]},{"id":"70ab713a4f74dd45","type":"change","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Close","rules":[{"t":"set","p":"payload","pt":"msg","to":"close","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":334,"y":171,"wires":[["16da3d6470fbf5b3","be96e999b41ef9c3","2fd0920ae195a08c"]],"icon":"font-awesome/fa-pause","l":false},{"id":"d653903dec8d6d52","type":"inject","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Open All","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":199,"y":231,"wires":[["f777b54c43dbc459"]]},{"id":"f777b54c43dbc459","type":"change","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Open","rules":[{"t":"set","p":"payload","pt":"msg","to":"open","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":334,"y":231,"wires":[["2fd0920ae195a08c","be96e999b41ef9c3","16da3d6470fbf5b3"]],"icon":"font-awesome/fa-play","l":false},{"id":"167d354ee679eea5","type":"link out","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"link out 620","mode":"link","links":["d8a157e1a366a049"],"x":444,"y":418,"wires":[]},{"id":"d8a157e1a366a049","type":"link in","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"link in 402","links":["167d354ee679eea5","16da3d6470fbf5b3","d1f696793750ea2b","85b3b42da75ab300"],"x":775,"y":334,"wires":[["c17a897d3f6a4dd4"]]},{"id":"39f9b21a2cfbda49","type":"link in","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"link in 403","links":["b63c2a8aef91c35e","be96e999b41ef9c3","95200c04d784565d","65c84738236aa8c8","edc82cd382f4c4a5"],"x":775,"y":434,"wires":[["4245f50364641925"]]},{"id":"929eba1173f83f56","type":"link in","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"link in 404","links":["7ddea6bdc78d9615","2fd0920ae195a08c","5e82a87ce52001cb","cd959317cef4f85d","7363745d56f6a1c5"],"x":775,"y":534,"wires":[["08f68ebffe65aaaa"]]},{"id":"2fd0920ae195a08c","type":"link out","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"link out 623","mode":"link","links":["929eba1173f83f56"],"x":444,"y":231,"wires":[]},{"id":"be96e999b41ef9c3","type":"link out","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"link out 624","mode":"link","links":["39f9b21a2cfbda49"],"x":444,"y":201,"wires":[]},{"id":"16da3d6470fbf5b3","type":"link out","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"link out 625","mode":"link","links":["d8a157e1a366a049"],"x":444,"y":171,"wires":[]},{"id":"95200c04d784565d","type":"link out","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"link out 626","mode":"link","links":["39f9b21a2cfbda49"],"x":444,"y":451,"wires":[]},{"id":"5e82a87ce52001cb","type":"link out","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"link out 627","mode":"link","links":["929eba1173f83f56"],"x":444,"y":483,"wires":[]},{"id":"f13a2d378842e397","type":"change","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Open","rules":[{"t":"set","p":"payload","pt":"msg","to":"open","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":334,"y":458,"wires":[["0ff757f5fac6e9e0","95200c04d784565d"]],"icon":"font-awesome/fa-play","l":false},{"id":"2bbdbdbb1ab1cc2c","type":"inject","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Open-2","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":189,"y":458,"wires":[["f13a2d378842e397"]]},{"id":"0ff757f5fac6e9e0","type":"change","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Close","rules":[{"t":"set","p":"payload","pt":"msg","to":"close","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":334,"y":418,"wires":[["167d354ee679eea5","5e82a87ce52001cb"]],"icon":"font-awesome/fa-pause","l":false},{"id":"d246a87d09d95dd4","type":"change","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Open","rules":[{"t":"set","p":"payload","pt":"msg","to":"open","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":334,"y":571,"wires":[["673b7d090613085c","5e82a87ce52001cb"]],"icon":"font-awesome/fa-play","l":false},{"id":"ac3ee171da59ee6c","type":"inject","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Open-3","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":189,"y":571,"wires":[["d246a87d09d95dd4"]]},{"id":"673b7d090613085c","type":"change","z":"633f7c1cbaea0e47","g":"0e7bbcca5061c4d8","name":"Close","rules":[{"t":"set","p":"payload","pt":"msg","to":"close","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":334,"y":531,"wires":[["95200c04d784565d","167d354ee679eea5"]],"icon":"font-awesome/fa-pause","l":false}]
