I am pretty new to node-red development and I am trying to bring up the most convenient dev environment.
I am writing a node with a complex server side code that uses external classes. Every time am making a syntax (or another) mistake, my node is not getting registered without any output. At this point, I can go ahead and run the code outside of node-red and see output like this (i.e. via external test code).
SyntaxError: Unexpected eval or arguments in strict mode
at wrapSafe (internal/modules/cjs/loader.js:1001:16)
at Module._compile (internal/modules/cjs/loader.js:1049:27)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
at Module.load (internal/modules/cjs/loader.js:950:32)
at Function.Module._load (internal/modules/cjs/loader.js:790:12)
at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
at internal/main/run_main_module.js:17:47
But I'd like to see the error with a backtrace when executed as a node.
Is there a way to do it?
