We're opening the Public Beta of NR Connect (@nr-connect/node-red) and would love feedback from the community.
While consulting with Node-RED users across industrial, commercial, and self-hosted deployments, the same set of requirements came up repeatedly:
Exposing FlowFuse Dashboard 2.0 remotely without opening firewall ports or installing VPN clients on every operator's phone.
Keeping the Flow Editor (:1880) completely off-limits to dashboard users.
Controlling which Dashboard 2.0 pages each person can see and knowing who triggered an action inside flows.
Sending reliable mobile push alerts and exposing specific webhooks without opening the entire Node-RED server.
We built NR Connect to sit in the middle ground: while FlowFuse is a great full platform for larger fleet management, many of the teams and self-hosters we worked with already had Node-RED running on their own hardware and wanted something lighter-weight and more affordable than a full platform—without having to stitch together DIY reverse proxies, VPNs, and custom auth middleware. Everything installs straight from the Node-RED Palette Manager with zero settings.js edits.
Install @nr-connect/node-red from Manage palette and paste a single connection code into the NR Connect sidebar tab:
Split-Perimeter Remote Access: Admins get the Flow Editor + Dashboard; invited Operators are strictly confined to /dashboard (Flow Editor & Admin endpoints return 403).
FlowFuse Dashboard 2.0 Page-Level Permissions: Automatically discovers your ui-page nodes and filters /dashboard/_setup, Socket.IOui-config, live widget broadcasts, and widget actions per user.
Signed User Identity in Flows (msg._client.user): Hooks into Dashboard 2.0 so widget events include { userId, email, name, role }—ideal for audit logging or restricting write actions in a switch/function node.
Native Web Push Notifications: Includes the nrc notify node (target all members, admins only, specific emails, or a specific Dashboard 2.0 page) and the nrc profile Dashboard 2.0 widget (avatar menu + one-click push opt-in + sign out).
Granular Public Webhooks: Expose specific HTTP In webhook paths (open or Bearer secret-key protected) while keeping the rest of Node-RED private.
Built for Self-Hosted Environments: Supports Linux (x64/arm64/arm), Raspberry Pi, Docker (including stateless NR_CONNECT_TOKEN containers), and unprivileged Proxmox LXCs.
Try it in 60 seconds
Create a free account at nr-connect.com (open beta, no waitlist).
Click Add instance to reserve your subdomain and copy your connection code. For your first instance, you’ll also choose a permanent workspace prefix.
In Node-RED: Manage palette → Install → @nr-connect/node-red, open the NR Connect sidebar tab, paste your code, and click Connect.
(Optional) Import the built-in example flow: Menu → Import → Examples → @nr-connect/node-red → starter-demo.
We want to be transparent about plans from day one:
Free ($0/mo): 1 Node-RED instance, share all dashboard pages with 1 person, 1 open public URL, and push notifications.
Pro ($9/mo) & Business ($29/mo): Multi-instance (5 / 20), up to 10 / unlimited people per instance, page-level dashboard permissions, admin sharing, secret-key protected webhooks, and "Require secure access" (block direct LAN connections).
Launch Offer: Use promo code LAUNCHPRO at checkout when signing up for Pro (monthly) to get your first month free (first-time customers, limited to the first 100 redemptions—cancel anytime if it's not a fit).
We'd love to hear how it performs across Raspberry Pi, Docker, Proxmox LXC, and multi-site Dashboard 2.0 setups—reply here, join us on Discord, or open an issue on GitHub.
Questions, architectural feedback, and edge-case reports are all very welcome!
Hi and thanks for sharing this. I've moved it into the Vendors category though since it is a commercial product.
I'd be interested, from a security perspective, whether you are able to protect more than just Dashboard 2? What about Dashboard 1, http-in/-response endpoints and UIBUILDER endpoints?
Also, in regard to D2, do you prevent D2 from sending route data to the client? D2 is an SPA after all and so may have data in-memory for other routes (I've not checked recently so not sure).
And, as the code is not currently open source as far as I can see, are you providing any independent security certification?
Thanks for moving it to Vendors—and for the great security questions! Here is where things stand today in the actual implementation:
1. Protecting more than Dashboard 2 (Dashboard 1, http-in/http-response, UIBUILDER)
At the perimeter, everything on the Node-RED instance is default-deny remotely: unauthenticated requests are blocked at the edge unless they match an explicitly configured public webhook prefix, and when Require secure access is enabled locally, the plugin prepends middleware to RED.httpNode, RED.httpAdmin, and RED.server's WebSocket upgrade listener so unsigned non-loopback HTTP and WebSocket traffic is rejected across all endpoints (requests from the edge carry per-request HMAC-SHA256 signatures with method+path binding and a bounded replay window).
How each target behaves for Admins vs. Operators today:
Dashboard 1 (/ui & /ui/*): Protected at the perimeter for both Admins and Operators (Operators can access /ui/* while the Editor/Admin endpoints return 403). However, page-level RBAC and msg._client.user injection are currently specific to Dashboard 2.0—Dashboard 1 only gets perimeter auth + Editor isolation.
http-in / http-response: Protected by default. Authenticated Admins can call any http-in route (with verified user identity attached), and individual prefixes can be exposed as Public URLs (either open or Bearer secret-key verified at the edge with SHA-256 constant-time comparison; traversal patterns like ../%2e/%2f are rejected and webhook tokens cannot reach Admin/Editor paths). Today, Operators receive 403 on arbitrary http-in paths outside /dashboard/*, /ui/*, and /resources/*.
UIBUILDER: Protected by default behind the same edge auth, ACL, and local Require secure access check (both HTTP and WebSocket upgrades), and accessible to authenticated Admins. Today, Operators receive 403 on custom UIBUILDER paths because the non-admin allowlist is currently scoped to /dashboard/*, /ui/*, and /resources/*.
Adding configurable Operator-accessible path prefixes (so non-admins can access specific UIBUILDER apps or authenticated http-in APIs, along with their Socket.IO paths and verified user headers) is very doable—I'd genuinely love your input on the routing/Socket.IO patterns UIBUILDER users most commonly rely on.
2. Dashboard 2.0 SPA route data & in-memory leakage
Yes—we explicitly do not rely on client-side hiding. Unpermitted pages, groups, and widgets are stripped server-side inside Node-RED before they ever leave the host:
Initial SPA config (ui-config over Socket.IO & GET /dashboard/_setup): Before emitting ui-config to a socket or returning /_setup, the plugin filters pages, groups (only those belonging to permitted pages), widgets (only those in permitted groups/pages), and meta.wysiwyg against the cryptographically signed allowed-pages list. The browser's SPA store/router never receives definitions for restricted pages.
Live broadcasts & state sync: Each restricted socket's outbound emit is wrapped to check msg-input:<id>, widget-load:<id>, and widget-sync:<id> against the user's allowed pages (failing closed if an ID cannot be resolved to a permitted page) and drops events for restricted widgets before they hit the wire. ui-control:* payloads also have references to forbidden pages, groups, and widgets stripped.
Inbound events & debug stores: Via Dashboard 2.0's plugin hooks (onAction, onChange, onSend, onLoad), forged inbound widget events targeting restricted widget IDs are dropped before reaching flows, and /_debug/datastore/:id / /_debug/statestore/:id return 403 for restricted items.
One honest caveat: Dashboard-wide (ui-scoped) widgets not bound to a specific page/group (such as an app-bar widget or built-in ui-notification) are shared across pages by design, so flows shouldn't push page-restricted secrets into a UI-wide widget.
3. Open source & independent security certification
To be completely upfront: no, we do not have an independent security certification (such as SOC 2 or ISO 27001) or a third-party pentest report yet at this Public Beta stage.
That said, here is the exact split of what is inspectable today vs. proprietary:
On your Node-RED host (inspectable / open):
The @nr-connect/node-red runtime plugin is MIT-licensed and published as plain, unminified JavaScript on npm—so every line of signature verification, Express/Socket.IO interception, and Dashboard 2.0 filtering running in your Node-RED process can be audited directly. (Fair point that it isn't easy to browse without pulling the npm package yet—publishing the plugin source directly to a public GitHub repo is on our near-term list.)
The outbound tunnel binary is the official open-source cloudflared release, verified against pinned SHA-256 digests (or you can pre-install cloudflared on PATH yourself and the plugin won't download or modify it).
Cloud control plane & edge proxy: The portal and Cloudflare edge worker enforcing auth/ACLs and signing per-request headers are closed-source SaaS components.
We're also documenting the security model in more detail (nr-connect.com/docs/secure-access) and will evaluate third-party security assessments as adoption grows, while being transparent now for teams that have hard compliance/certification requirements.
Feel free to PM me for a more detailed discussion. Probably best to keep off the open threads initially. Happy to have a discussion about the best way to handle things. UIBUILDER v8 (major upgrade) is currently well under way so now would be a good time if changes are needed at my end.
UIBUILDER has a number of standard endpoints both for the Editor and for user-facing UI's. But it also creates a route for every "url" in a uibuilder node and also for every Markweb node. Those routes have a lot of flexibility. Those routes also host the Socket.IO endpoints.
In addition, UIBUILDER allows Node-RED admins the ability to use a separate ExpressJS server for endpoints (e.g. not RED.httpNode) should a separate ExpressJS configuration to the main one be needed. This might be the case for specialist security or to have different settings to Node-RED's Dashboards and http-in.
UIBUILDER does carry well-known IdM HTTP headers so that they can be worked with (as does D2) but it does not enforce security itself because there are just too many possible requirements (for several years I did try to find a flexible solution internally but it was pointless, external tools and custom middleware does a far more effective job). What it does is ensure that the appropriate information is available and exposes a number of hooks and middleware points to allow enforcing of whatever IdM schemes people might want. I've no doubt we can engineer a suitable hook to allow your system to apply your security. The code is open source so you are free to examine it and I'm happy to answer questions. If you do look, please use the "dev" branch which is what will be v8.
I didn't expect you to have anything yet. I was just looking for your response and hinting that, without something, you are either opening up your customers to risk or yourselves. Possibly both. It is important that everyone understands the risks and possible mitigations.
That's good - but probably needs to be documented - unless I missed it. Because obviously that does get updated by Cloudflare fairly regularly and would need customers to manage that.
OK, that's good, that was going to be my other suggestion. Hopefully this discussion gives some areas for documentation to cover.
That's cool. I think you do need to be clear about that in your documentation though.
Exciting for Node-RED to have a new player in this space, it is ever more important.
I'm no longer in the market for these things as I'm retired but I still have a keen interest in security as you can probably tell. I wish you the best in your endevours.
