Quadratic equation plot with ui_chart - Dashboard 2.0
Hello there,
New to Node Red and I'm trying to plot quadratic equation using function below:
// Quadratic coefficients
const a = 1;
const b = -2;
const c = 1;
// Generate data points
const points = [];
for (let x = -10; x <= 10; x += 0.5) {
    const y = a * x * x + b * x + c;
    points.push({ x: x, y: y });
// Format for ui_chart (Dashboard 2.0)
msg.payload = [
        label: "y = ax² + bx + c",
        data: points
problem with plotting with ui_chart. it doesn't accept data as array but it can only read data in object pair of { x: x, y: y } with only plot one point. how can I plot whole graphic for x =-10 to 10 using ui_chart?
Sure it does. Just put your data in the shape expected as per several of the documented examples in the online documentation.
Try this (untested)
const a = 1;
const b = -2;
const c = 1;
const points = [];
msg.payload = points
Be sure to set the label in the chart edit panel (or use dynamic props as described in docs)
also, set the x to come from key.x and y to come from key.y
Great, this is exactly what I needed.
