For flows created with Node-RED, text only exchanges are normally done
I can not understand how to set response type option and image set in Watson Assistant Dialog and it is stopped.
Output options of "Option" and "Image" do not correspond to Assistant nodes alone
How can I set Opiton and Image of Response with Node - RED?
Does the node use Function or Templete (mustache format)?
↑ How should I write?
After sending a question, Assistant can now get the URL of the image, but I do not know how to put out the display with the chat bot.
Do you know how to set the GET URL using which node tag?
