Queue is reversing my payload order
Hi everyone,
I'm having an issue using a SimpleQueue where the messages instead of being FIFO are coming out FILO, am I doing anything wrong here?
Flow
Template
Function node
Outcome in text
Flow export:
[{"id":"c3f2355a.e2e448","type":"tab","label":"Flow 6","disabled":false,"info":""},{"id":"5d02f3d6.cab01c","type":"template","z":"c3f2355a.e2e448","name":"","field":"payload","fieldType":"msg","format":"json","syntax":"mustache","template":"[{"progress":1},\n{"progress":2},\n{"progress":3},\n{"progress":4},\n{"progress":5},\n{"progress":6},\n{"progress":7},\n{"progress":8},\n{"progress":9},\n{"progress":10}]","output":"str","x":650,"y":400,"wires":[["76c83ae2.78b004"]]},{"id":"fa9d01a4.fea7","type":"inject","z":"c3f2355a.e2e448","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":500,"y":400,"wires":[["5d02f3d6.cab01c"]]},{"id":"76c83ae2.78b004","type":"split","z":"c3f2355a.e2e448","name":"","splt":"\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":790,"y":400,"wires":[["fc81d29b.98edb"]]},{"id":"619ee052.bdc24","type":"file","z":"c3f2355a.e2e448","name":"","filename":"E:\Kris Temp Files\QueueTesting.json","appendNewline":true,"createDir":false,"overwriteFile":"false","encoding":"none","x":1330,"y":380,"wires":[["1d6fec1c.248804"]]},{"id":"fc81d29b.98edb","type":"simple-queue","z":"c3f2355a.e2e448","name":"","count":"1","unique_check":"","x":1020,"y":380,"wires":[["619ee052.bdc24"]]},{"id":"1d6fec1c.248804","type":"function","z":"c3f2355a.e2e448","name":"","func":"msg.trigger = true;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1120,"y":480,"wires":[["fc81d29b.98edb"]]}]
Add a debug node showing what is going into the queue and another showing what is coming out and check whether it is actually the queue that is failing.
And reformat your flow, it cannot be imported!
