Raspberry PI 4 GPIO
When you say "Yes," do you mean my code doesn't work or it does work on your Pi? :slight_smile:
The above code is what I used to get a result
using GPIO.BOARD fails
I see the same result as you with regards to BCM and BOARD
I've raised a bug with the RPi.GPIO author
I've tried out the pigpio node which works using gpio numbering but I can't get it to even control standard pins - its website says it might not work on the Pi4 and it seems it doesn't at the moment :frowning: #NotWinning
Haha that will teach me to not fully study the RPI pinouts before designing a 4 layer PCB.
Thankfully when I designed the board I designed it with a 44 pin pic onboard that also links to the 14 outputs so I'll just use that for this version of the board with PI communications to that chip, would have just been more convenient having the PI deal with all outputs.
#PlanB
did anyone test this with node-red?
