Raspberry Pi dies when left on overnight
I accidentally left my Raspberry Pi on overnight. When I discovered that the next day I also found that I couldn't get it to respond. I've tried cycling power but never gotten it to respond since then. If I recall correctly, the red led is on but the green led which used to flash on and off no longer comes.
I'd like to be able to leave it on for extended periods for some of the things I'd like to do. Is this a heat issue? I did apply the little heat sink to the CPU chip on the board but don't know what to do with the other small piece that was supplied with the kit that had the raspberry symbol on it. Does that matter?
Thanks in advance for any ideas/insights.
There should be no problems when leaving a Raspberry Pi running for long periods. I have a Pi 3 in my network that has been running for 11 months. Please tell us a little more about your setup.
I recommend asking this over on the official raspberry pi forum to get better help than on this one
No green led is a damaged sd card, try another (better brand) sd card.
Have you got anything wired directly into it, or one of the PiHats for example? If so disconnect all those and try again
Otherwise I would burn another SD card and see if that fixes it.
If not then it may be broken.
Thanks Colin. I got several responses that mentioned the SD card so I will switch card (I have another) and will see if that fixes it. Thanks.
Thanks. I’ll switch SD cards and see what happens.
Hey Simon. How do I do that? (I didn’t realize that I wasn’t addressing the official forum). Thanks!
Glad to hear this. Sounds like it might be the SD card. I’ll replace and see if that fixes the issue. Thanks!
https://www.raspberrypi.org/forums/
This is the node-red forum, which isn't specifically Pi related, though many do use the Pi.
