Raspberry Pi - Stopped flow missing node types - server
Can't figure out how to repair. All flows appear, but Dashboard is inaccessible. Nothing works.
Dump of log:
Starting as a systemd service.
20 May 20:42:37 - [info]
Welcome to Node-RED
20 May 20:42:37 - [info] Node-RED version: v1.2.2
20 May 20:42:37 - [info] Node.js version: v12.20.2
20 May 20:42:37 - [info] Linux 5.10.11-v7+ arm LE
20 May 20:42:39 - [info] Loading palette nodes
20 May 20:42:43 - [info] Dashboard version 2.29.0 started at /ui
20 May 20:42:44 - [info] Settings file : /home/pi/.node-red/settings.js
20 May 20:42:44 - [info] Context store : 'default' [module=memory]
20 May 20:42:44 - [info] User directory : /home/pi/.node-red
20 May 20:42:44 - [warn] Projects disabled : editorTheme.projects.enabled=false
20 May 20:42:44 - [info] Flows file : /home/pi/.node-red/flows_Workbench3.json
20 May 20:42:44 - [info] Server now running at http://127.0.0.1:1880/
20 May 20:42:44 - [info] Waiting for missing types to be registered:
20 May 20:42:44 - [info] - server
Goto configuration tab on right, click unused, click on unused items and hit delete. Then deploy.
Well, in my many years in tech, I've never received such a brief and effective solution! Many thanks for that. Up and running and back to the way I was. Have a great weekend.
I am not into waffling. LOL
[edit
I was thinking
config>unused>click>delete>deploy
but thought it was a bit cryptic.]
You're clearly an engineer. Get to the point, get the job done, and move on. Just the way I like it :slight_smile:
Thanks again
