Is there somewhere where you can the supported version OS/NR.
So I can see strech, buster, bullseye highests NR versions that can be installed
The constraint is whether NodeJS can be installed.
Older platforms may only have access to out-of-support versions (v18 LTS and above are still in support)
Node-RED recommends even numbered NodeJS (odd numbered versions are not tested, nor supported, nor recommended)
If you can install nodejs v14 or above, node-red 3.x is supported - however I strongly recommend using V18 or V20 LTS
And Bookworm
Though Stretch is out of support and Buster is only LTS until June24. So bullseye and bookworm are best options for now.
