Here are my flow(s):
[{"id":"288b8093.84499","type":"tab","label":"Files","disabled":false,"info":""},{"id":"1b46711c.36755f","type":"inject","z":"288b8093.84499","name":"","props":[{"p":"payload","v":"","vt":"date"},{"p":"topic","v":"","vt":"string"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":140,"y":120,"wires":[["f3f6e723.158a08"]]},{"id":"d8c34461.bd2778","type":"debug","z":"288b8093.84499","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":590,"y":100,"wires":[]},{"id":"4f5db71a.626968","type":"comment","z":"288b8093.84499","name":"SD Card File Browser","info":"","x":120,"y":60,"wires":[]},{"id":"5802319f.e1104","type":"function","z":"288b8093.84499","name":"Format data","func":"msg.options = [];\nfor (var i=0; i<msg.payload.length; i++) {\n obj = {};\n obj [msg.payload[i].name]=msg.payload[i].name;\n msg.options.push(obj);\n}\nmsg.payload={};\nreturn msg;","outputs":1,"noerr":0,"x":590,"y":160,"wires":[["eef70c85.448f8"]]},{"id":"2eef2e74.325762","type":"template","z":"288b8093.84499","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<table width=\"100%\">\n <tr><th>File Name</th><th>Size</th><th>Created</th><th>Changed</th></tr>\n {{#payload}}\n <tr>\n <td><a href=\"/red/download?filename={{name}}\" target=\"blank\">{{fname}}</a></td>\n <td>{{stat.size}}</td>\n <td>{{stat.created}}</td>\n <td>{{stat.changed}}</td>\n </tr>\n {{/payload}}\n</table>\n","output":"str","x":820,"y":220,"wires":[["a1ba22bc.8a352"]]},{"id":"cc85cf75.0551f","type":"function","z":"288b8093.84499","name":"Convert timestamps","func":"\nfor (var i=0; i<msg.payload.length; i++) {\n msg.payload[i].stat.created = msg.payload[i].stat.created.toISOString().slice(0, 19).replace('T', ' ');\n msg.payload[i].stat.changed = msg.payload[i].stat.changed.toISOString().slice(0, 19).replace('T', ' ');\n msg.payload[i].stat.accessed = msg.payload[i].stat.accessed.toISOString().slice(0, 19).replace('T', ' ');\n msg.payload[i].stat.statusChanged = msg.payload[i].stat.statusChanged.toISOString().slice(0, 19).replace('T', ' ');\n msg.payload[i].fname = msg.payload[i].name.replace(/^.*(\\\\|\\/|\\:)/, '');\n}\nreturn msg;","outputs":1,"noerr":0,"x":620,"y":220,"wires":[["2eef2e74.325762"]]},{"id":"7a30e131.3ab18","type":"function","z":"288b8093.84499","name":"Save selection","func":"// Save the file name selected from the dropdown in the flow context\nflow.set(\"fileselected\", msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":1020,"y":160,"wires":[[]]},{"id":"4580f3e7.258ccc","type":"function","z":"288b8093.84499","name":"Get filename","func":"// Get the filename from the flow context\nlet filename = flow.get(\"fileselected\");\n\n// check, if the filename is undefined that means it does not exist yet, nothing is selected yet\n// return: do not output anything\nif (filename===undefined) {\n return;\n}\n\n// return the filename to the file-in node to delete\nmsg.filename = filename;\n\n// and delete the context/selection as we are deleting the file as well\nflow.set(\"fileselected\");\nreturn msg;","outputs":1,"noerr":0,"x":280,"y":320,"wires":[["928b635a.e4512"]]},{"id":"928b635a.e4512","type":"file","z":"288b8093.84499","name":"Delete file","filename":"","appendNewline":true,"createDir":false,"overwriteFile":"delete","encoding":"none","x":460,"y":320,"wires":[["f3f6e723.158a08"]]},{"id":"95a6b885.c4e078","type":"http in","z":"288b8093.84499","name":"","url":"/download","method":"get","upload":false,"swaggerDoc":"","x":150,"y":380,"wires":[["eb9b4b79.9a2888"]]},{"id":"c2ff398b.e2c488","type":"http response","z":"288b8093.84499","name":"","statusCode":"","headers":{},"x":940,"y":380,"wires":[]},{"id":"eb9b4b79.9a2888","type":"function","z":"288b8093.84499","name":"Get the file name","func":"msg.filename = msg.req.query.filename;\nmsg.contentdisposition = \"attachment; filename=\\\"\" + msg.req.query.filename.replace(/^.*(\\\\|\\/|\\:)/, '') + \"\\\"\";\nreturn msg;","outputs":1,"noerr":0,"x":400,"y":380,"wires":[["fb3511a4.a7baa"]]},{"id":"fb3511a4.a7baa","type":"file in","z":"288b8093.84499","name":"","filename":"","format":"","chunk":false,"sendError":false,"encoding":"none","x":590,"y":380,"wires":[["d2400b86.0a7258"]]},{"id":"d2400b86.0a7258","type":"change","z":"288b8093.84499","name":"Set Headers","rules":[{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"headers.content-type","pt":"msg","to":"text/csv","tot":"str"},{"t":"set","p":"headers.Content-Disposition","pt":"msg","to":"contentdisposition","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":380,"wires":[["c2ff398b.e2c488"]]},{"id":"5c190aeb.7bef74","type":"comment","z":"288b8093.84499","name":"Autologger ","info":"","x":80,"y":620,"wires":[]},{"id":"24c92f55.fc08d","type":"function","z":"288b8093.84499","name":"Filename generator","func":"// Get the current time and convert it to text\nvar now = new Date();\nvar yyyy = now.getFullYear();\nvar mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1); // getMonth() is zero-based\nvar dd = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\nvar hh = now.getHours() < 10 ? \"0\" + now.getHours() : now.getHours();\nvar mmm = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\nvar ss = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds();\n\n// Generate out file name pattern\nmsg.fname = \"logging_\"+ yyyy + mm + dd + \".csv\";\n// Full filename with path for the file node later\nmsg.filename = \"/run/media/mmcblk0p1/\"+ msg.fname;\n\n// We save the current payload into a different place on the msg object\nmsg.filecontent = msg.payload;\n\n// We are passing the file name search pattern to fs node to tell us if the file exists or not\nmsg.payload = {\"pattern\":msg.fname};\n\nnode.status({fill:\"blue\",shape:\"ring\",text:msg.fname});\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":196,"y":787,"wires":[["35c6d0f7.c0b01"]]},{"id":"1836e6c2.b5c749","type":"switch","z":"288b8093.84499","name":"","property":"$count(msg.payload)","propertyType":"jsonata","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":536,"y":787,"wires":[["31da97fb.5b9428"],["62e86e59.f3b59"]]},{"id":"84fa66a.5893598","type":"csv","z":"288b8093.84499","name":"","sep":";","hdrin":"","hdrout":"all","multi":"one","ret":"\\n","temp":"","skip":"0","strings":true,"include_empty_strings":false,"include_null_values":false,"x":1190,"y":760,"wires":[["b305d747.4639c8"]]},{"id":"b305d747.4639c8","type":"file","z":"288b8093.84499","name":"","filename":"","appendNewline":false,"createDir":true,"overwriteFile":"false","encoding":"none","x":1336,"y":767,"wires":[[]]},{"id":"7f99918a.27e0c","type":"csv","z":"288b8093.84499","name":"","sep":";","hdrin":"","hdrout":"none","multi":"one","ret":"\\n","temp":"","skip":"0","strings":true,"include_empty_strings":false,"include_null_values":false,"x":1190,"y":800,"wires":[["b305d747.4639c8"]]},{"id":"31da97fb.5b9428","type":"change","z":"288b8093.84499","name":"Get file content","rules":[{"t":"set","p":"payload","pt":"msg","to":"filecontent","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":760,"wires":[["6904d180.18353"]]},{"id":"62e86e59.f3b59","type":"change","z":"288b8093.84499","name":"Get file content","rules":[{"t":"set","p":"payload","pt":"msg","to":"filecontent","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":800,"wires":[["4941746b.54fb5c"]]},{"id":"d743ed09.0b366","type":"comment","z":"288b8093.84499","name":"Graph the data","info":"","x":126,"y":1072,"wires":[]},{"id":"9a41fa60.3a05d8","type":"function","z":"288b8093.84499","name":"Get filename","func":"// Get the filename from the flow context\nlet filename = flow.get(\"fileselected\");\n\n// check, if the filename is undefined that means it does not exist yet, nothing is selected yet\n// return: do not output anything\nif (filename===undefined) {\n return;\n}\n\n// return the filename to the file-in node to delete\nmsg.filename = filename;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":370,"y":1120,"wires":[["652cec50.f88e54"]]},{"id":"652cec50.f88e54","type":"file in","z":"288b8093.84499","name":"","filename":"","format":"utf8","chunk":false,"sendError":false,"encoding":"none","x":540,"y":1117,"wires":[["c3cea279.83c91"]]},{"id":"c3cea279.83c91","type":"csv","z":"288b8093.84499","name":"","sep":";","hdrin":true,"hdrout":"","multi":"mult","ret":"\\n","temp":"","skip":"0","strings":true,"include_empty_strings":false,"include_null_values":false,"x":690,"y":1117,"wires":[["fd32e5f6.ae37e8","df393d88.a130f"]]},{"id":"150a8568.bc258b","type":"inject","z":"288b8093.84499","name":"Every 10min","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"600","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":140,"y":1160,"wires":[["9a41fa60.3a05d8"]]},{"id":"6904d180.18353","type":"change","z":"288b8093.84499","name":"timestamp to time","rules":[{"t":"set","p":"payload.Tijdstip","pt":"msg","to":"time","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":760,"wires":[["207d51ce.c7d1ae"]]},{"id":"4941746b.54fb5c","type":"change","z":"288b8093.84499","name":"Timestamp to time","rules":[{"t":"set","p":"payload.Tijdstip","pt":"msg","to":"time","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":800,"wires":[["e9d7323a.ce38a8"]]},{"id":"f27b11a4.8acdf","type":"function","z":"288b8093.84499","name":"Set data","func":"msg.payload = { \n [global.get(\"AI00.name\")]: global.get(\"AI00.value\"), \n [global.get(\"AI01.name\")]: global.get(\"AI01.value\"),\n [global.get(\"AI02.name\")]: global.get(\"AI02.value\"),\n [global.get(\"AI03.name\")]: global.get(\"AI03.value\")};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":613,"y":698,"wires":[["6c219724.5f8d18"]]},{"id":"dd4bb6e.cf31448","type":"ui_chart","z":"288b8093.84499","name":"","group":"6939346c.3cdb8c","order":1,"width":0,"height":0,"label":"File data","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"1500","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":1220,"y":1117,"wires":[[]]},{"id":"a1ba22bc.8a352","type":"ui_template","z":"288b8093.84499","group":"f14bc46d.61ef78","name":"","order":5,"width":0,"height":0,"format":"<div ng-bind-html=\"msg.payload\" height=\"400\" style=\"height: 400px;\"><br/>\n</div>\n\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":1000,"y":220,"wires":[[]]},{"id":"eef70c85.448f8","type":"ui_dropdown","z":"288b8093.84499","name":"File Selector","label":"","tooltip":"","place":"Select a file","group":"f14bc46d.61ef78","order":4,"width":0,"height":0,"passthru":false,"multiple":false,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","topicType":"str","className":"","x":790,"y":160,"wires":[["7a30e131.3ab18"]]},{"id":"a44db5d6.5d2b28","type":"ui_button","z":"288b8093.84499","name":"","group":"f14bc46d.61ef78","order":1,"width":0,"height":0,"passthru":false,"label":"Refresh","tooltip":"","color":"","bgcolor":"","className":"","icon":"refresh","payload":"","payloadType":"str","topic":"","topicType":"str","x":140,"y":160,"wires":[["f3f6e723.158a08"]]},{"id":"756b5c80.2e1554","type":"ui_button","z":"288b8093.84499","name":"","group":"f14bc46d.61ef78","order":3,"width":0,"height":0,"passthru":false,"label":"Delete","tooltip":"","color":"","bgcolor":"","className":"","icon":"delete","payload":"","payloadType":"str","topic":"","topicType":"str","x":110,"y":320,"wires":[["4580f3e7.258ccc"]]},{"id":"67615f6d.285b3","type":"ui_button","z":"288b8093.84499","name":"","group":"f14bc46d.61ef78","order":2,"width":0,"height":0,"passthru":false,"label":"Graph","tooltip":"","color":"","bgcolor":"","className":"","icon":"show_chart","payload":"","payloadType":"str","topic":"","topicType":"str","x":190,"y":1117,"wires":[["9a41fa60.3a05d8"]]},{"id":"950f805f.eb259","type":"debug","z":"288b8093.84499","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1230,"y":1160,"wires":[]},{"id":"fd32e5f6.ae37e8","type":"function","z":"288b8093.84499","name":"","func":"let dataLabels = [];\nlet data1 = [[]];\nlet data2 = [[]];\nlet data3 = [[]];\nlet data4 = [[]];\nfor (let X in msg.payload) \n{\n dataLabels[X] = msg.payload[X].Tijdstip;\n data1[0][X] = msg.payload[X].Geleidbaarheid;\n data2[0][X] = msg.payload[X].Druk;\n data3[0][X] = msg.payload[X].Sensor3;\n data4[0][X] = msg.payload[X].Sensor4;\n}\n\n\n\nvar m={\n \"series\": [\"Sensor1\",\"sensor2\",\"sensor3\",\"sensor4\"], // Legenda \n \"data\": [data1[0],data2[0],data3[0],data4[0]], // Waarde van staafdiagram y-as\n \"labels\": dataLabels // Momenten van data X-as\n};\n\nreturn {payload:[m]};","outputs":1,"noerr":0,"initialize":"","finalize":"","x":960,"y":1120,"wires":[["950f805f.eb259","dd4bb6e.cf31448"]]},{"id":"3606fd3c.c9b3b2","type":"function","z":"288b8093.84499","name":"Filename generator","func":"// Get the current time and convert it to text\nvar now = new Date();\nvar yyyy = now.getFullYear();\nvar mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1); // getMonth() is zero-based\nvar dd = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\nvar hh = now.getHours() < 10 ? \"0\" + now.getHours() : now.getHours();\nvar mmm = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\nvar ss = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds();\n\n// Generate out file name pattern\nmsg.fname = \"logging_\"+ yyyy + mm + \".csv\";\n// Full filename with path for the file node later\nmsg.filename = \"/run/media/mmcblk0p1/\"+ msg.fname;\n\n// We save the current payload into a different place on the msg object\nmsg.filecontent = msg.payload;\n\n// We are passing the file name search pattern to fs node to tell us if the file exists or not\nmsg.payload = {\"pattern\":msg.fname};\n\nnode.status({fill:\"blue\",shape:\"ring\",text:msg.fname});\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":190,"y":920,"wires":[["c07881d6.073e3"]]},{"id":"5ba2ec41.5250f4","type":"inject","z":"288b8093.84499","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":90,"y":860,"wires":[["3606fd3c.c9b3b2"]]},{"id":"d683b176.78a9e","type":"function","z":"288b8093.84499","name":"Set data","func":"msg.payload = {\n \n \"pattern\" : \"logging_\"+ msg.payload + \".csv\",\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":620,"y":920,"wires":[["3896c5fe.148baa"]]},{"id":"b54fa671.282c18","type":"switch","z":"288b8093.84499","name":"","property":"$count(msg.payload)","propertyType":"jsonata","rules":[{"t":"eq","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":930,"y":920,"wires":[["4bc1e4a0.81e55c"]]},{"id":"4d09ca5e.3ecf54","type":"file","z":"288b8093.84499","name":"Delete file","filename":"","appendNewline":true,"createDir":false,"overwriteFile":"delete","encoding":"none","x":1260,"y":920,"wires":[["482daecf.ff94d"]]},{"id":"4bc1e4a0.81e55c","type":"function","z":"288b8093.84499","name":"Set data","func":"msg.filename = msg.payload;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1100,"y":920,"wires":[["4d09ca5e.3ecf54"]]},{"id":"644fbccd.dcfce4","type":"link in","z":"288b8093.84499","name":"Refresh","links":["482daecf.ff94d"],"x":135,"y":220,"wires":[["f3f6e723.158a08"]]},{"id":"482daecf.ff94d","type":"link out","z":"288b8093.84499","name":"","links":["644fbccd.dcfce4"],"x":1375,"y":920,"wires":[]},{"id":"df393d88.a130f","type":"debug","z":"288b8093.84499","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1030,"y":1240,"wires":[]},{"id":"f3f6e723.158a08","type":"fs-file-lister","z":"288b8093.84499","name":"","start":"/run/media/mmcblk0p1/","pattern":"*.*","folders":"*","hidden":true,"lstype":"files","path":true,"single":true,"depth":0,"stat":true,"showWarnings":true,"x":340,"y":140,"wires":[["d8c34461.bd2778","5802319f.e1104","cc85cf75.0551f"]]},{"id":"35c6d0f7.c0b01","type":"fs-file-lister","z":"288b8093.84499","name":"","start":"/run/media/mmcblk0p1/","pattern":"","folders":"*","hidden":true,"lstype":"files","path":true,"single":true,"depth":0,"stat":true,"showWarnings":true,"x":386,"y":787,"wires":[["1836e6c2.b5c749"]]},{"id":"3896c5fe.148baa","type":"fs-file-lister","z":"288b8093.84499","name":"","start":"/run/media/mmcblk0p1/","pattern":"","folders":"*","hidden":true,"lstype":"files","path":true,"single":false,"depth":0,"stat":false,"showWarnings":true,"x":780,"y":920,"wires":[["b54fa671.282c18"]]},{"id":"120d8a3f.a92596","type":"moment","z":"288b8093.84499","name":"","topic":"","input":"payload","inputType":"msg","inTz":"Europe/London","adjAmount":"2","adjType":"hours","adjDir":"subtract","format":"LLL","locale":"C","output":"time","outputType":"msg","outTz":"Europe/Amsterdam","x":413,"y":698,"wires":[["f27b11a4.8acdf"]]},{"id":"c07881d6.073e3","type":"moment","z":"288b8093.84499","name":"","topic":"","input":"payload","inputType":"msg","inTz":"Europe/Amsterdam","adjAmount":"1","adjType":"years","adjDir":"subtract","format":"YYYYMM","locale":"C","output":"payload","outputType":"msg","outTz":"Europe/Amsterdam","x":420,"y":920,"wires":[["d683b176.78a9e"]]},{"id":"1eaa5e7d.760822","type":"inject","z":"288b8093.84499","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"5","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":90,"y":700,"wires":[["120d8a3f.a92596"]]},{"id":"207d51ce.c7d1ae","type":"function","z":"288b8093.84499","name":"","func":"\n\nmsg.columns = \"Tijdstip,\"+msg.name1+\",\"+msg.name2+\",\"+msg.name3+\",\"+msg.name4+\",\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1060,"y":760,"wires":[["84fa66a.5893598"]]},{"id":"6c219724.5f8d18","type":"change","z":"288b8093.84499","name":"","rules":[{"t":"set","p":"name1","pt":"msg","to":"AI00.name","tot":"global"},{"t":"set","p":"name2","pt":"msg","to":"AI01.name","tot":"global"},{"t":"set","p":"name3","pt":"msg","to":"AI02.name","tot":"global"},{"t":"set","p":"name4","pt":"msg","to":"AI03.name","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":700,"wires":[["24c92f55.fc08d"]]},{"id":"e9d7323a.ce38a8","type":"function","z":"288b8093.84499","name":"","func":"\n\nmsg.columns = \"Tijdstip,\"+msg.name1+\",\"+msg.name2+\",\"+msg.name3+\",\"+msg.name4+\",\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1060,"y":800,"wires":[["7f99918a.27e0c"]]},{"id":"26a582fa.c19396","type":"inject","z":"288b8093.84499","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"one\":1,\"two\":2},{\"three\":3,\"four\":4}]","payloadType":"json","x":250,"y":1320,"wires":[["b60fd602.e8f418"]]},{"id":"b60fd602.e8f418","type":"function","z":"288b8093.84499","name":"","func":"msg.payload = Object.keys(msg.payload[0]);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":1320,"wires":[["540f088.66ac2f8"]]},{"id":"540f088.66ac2f8","type":"debug","z":"288b8093.84499","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":810,"y":1320,"wires":[]},{"id":"6939346c.3cdb8c","type":"ui_group","z":"","name":"Bestand","tab":"b5e5ffd5.e6021","order":3,"disp":true,"width":20,"collapse":true,"className":""},{"id":"f14bc46d.61ef78","type":"ui_group","z":"","name":"Buttons","tab":"b5e5ffd5.e6021","order":1,"disp":false,"width":"8","collapse":false,"className":""},{"id":"b5e5ffd5.e6021","type":"ui_tab","z":"","name":" File","icon":"fa-file-excel-o","order":3,"disabled":false,"hidden":false}]
[{"id":"ce4bb0dd.a8435","type":"tab","label":"Sensor 1","disabled":false,"info":""},{"id":"b41fafca.5b9e2","type":"change","z":"ce4bb0dd.a8435","name":"","rules":[{"t":"set","p":"AI00_Name","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":280,"y":100,"wires":[["d637e4c5.2563a8","2caba41f.e07d84"]]},{"id":"e204f7c0.01bed8","type":"change","z":"ce4bb0dd.a8435","name":"","rules":[{"t":"set","p":"payload.online","pt":"msg","to":"true","tot":"bool"},{"t":"set","p":"payload.name","pt":"msg","to":"AI00_Name","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":180,"wires":[["af4ba3de.072a6"]]},{"id":"ba6e762c.adfa98","type":"switch","z":"ce4bb0dd.a8435","name":"","property":"AI00_Name","propertyType":"flow","rules":[{"t":"nempty"}],"checkall":"true","repair":false,"outputs":1,"x":230,"y":180,"wires":[["e7721a61.8ff888"]]},{"id":"e6a527fc.801118","type":"change","z":"ce4bb0dd.a8435","name":"","rules":[{"t":"set","p":"AI00","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1200,"y":180,"wires":[["72064ba4.9c14bc"]]},{"id":"59d23704.70b618","type":"uc-iodataIn","z":"ce4bb0dd.a8435","mode":"wi_single_variable","variable":"AI00","name":"","pollInterval":"2000","pollIntervalBase":"s","x":80,"y":180,"wires":[["ba6e762c.adfa98"],[]]},{"id":"7e1981ef.f7a45","type":"ui_dropdown","z":"ce4bb0dd.a8435","name":"","label":"","tooltip":"","place":"Kies sensor","group":"abcb8328.96141","order":4,"width":6,"height":1,"passthru":true,"multiple":false,"options":[{"label":"Temperatuur","value":"Temperatuur","type":"str"},{"label":"Geleidbaarheid","value":"Geleidbaarheid","type":"str"},{"label":"Flow","value":"Flow","type":"str"},{"label":"Druk","value":"Druk","type":"str"},{"label":"Leeg","value":false,"type":"bool"}],"payload":"","topic":"topic","topicType":"msg","className":"","x":80,"y":100,"wires":[["b41fafca.5b9e2"]]},{"id":"ddcf891c.9af918","type":"ui_text","z":"ce4bb0dd.a8435","group":"abcb8328.96141","order":3,"width":6,"height":1,"name":"","label":"Sensor 1","format":"","layout":"row-spread","className":"","x":80,"y":60,"wires":[]},{"id":"be946f9a.e78cb","type":"change","z":"ce4bb0dd.a8435","name":"","rules":[{"t":"set","p":"AI00.online","pt":"global","to":"false","tot":"bool"},{"t":"set","p":"AI00.value","pt":"global","to":"0","tot":"num"},{"t":"set","p":"AI00.name","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1200,"y":100,"wires":[[]]},{"id":"d637e4c5.2563a8","type":"switch","z":"ce4bb0dd.a8435","name":"","property":"AI00_Name","propertyType":"flow","rules":[{"t":"false"}],"checkall":"true","repair":false,"outputs":1,"x":550,"y":100,"wires":[["be946f9a.e78cb"]]},{"id":"af4ba3de.072a6","type":"function","z":"ce4bb0dd.a8435","name":"","func":"var value; \n\nvalue = msg.payload.value.toFixed(2);\n\nmsg.payload.value = parseFloat(value);\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1000,"y":180,"wires":[["e6a527fc.801118"]]},{"id":"33986851.57283","type":"ui_text_input","z":"ce4bb0dd.a8435","name":"","label":"Min","tooltip":"","group":"abcb8328.96141","order":7,"width":3,"height":1,"passthru":true,"mode":"number","delay":"0","topic":"topic","sendOnBlur":true,"className":"","topicType":"msg","x":90,"y":400,"wires":[["ee599125.399f18"]]},{"id":"95a468f9.ea9d4","type":"ui_text_input","z":"ce4bb0dd.a8435","name":"","label":"Max","tooltip":"","group":"abcb8328.96141","order":8,"width":3,"height":1,"passthru":true,"mode":"number","delay":"0","topic":"topic","sendOnBlur":true,"className":"","topicType":"msg","x":90,"y":360,"wires":[["bb69ee8b.ad4448"]]},{"id":"bb69ee8b.ad4448","type":"change","z":"ce4bb0dd.a8435","name":"","rules":[{"t":"set","p":"AI00.Max","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":360,"wires":[[]]},{"id":"ee599125.399f18","type":"change","z":"ce4bb0dd.a8435","name":"","rules":[{"t":"set","p":"AI00.Min","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":400,"wires":[[]]},{"id":"e7721a61.8ff888","type":"change","z":"ce4bb0dd.a8435","name":"Limits","rules":[{"t":"set","p":"minout","pt":"msg","to":"AI00.Min","tot":"global"},{"t":"set","p":"maxout","pt":"msg","to":"AI00.Max","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":180,"wires":[["64274f03.d31188"]]},{"id":"64274f03.d31188","type":"function","z":"ce4bb0dd.a8435","name":"Scale for colour","func":"var maxin = 27648;\nvar minin = 0;\nvar maxout = flow.get(\"AI00.Max\");\nvar minout = flow.get(\"AI00.Min\");\nvar X = parseInt(msg.payload.value);\n\nif (msg.payload < minin)\n{\n msg.payload = 0;\n return msg;\n}\nvar value = parseFloat((((maxout - minout) / (maxin - minin) * ( X - minin)) + minout));\n\nmsg.payload.value = value;\nmsg.payload.Max = maxout;\nmsg.payload.Min = minout;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":560,"y":180,"wires":[["e204f7c0.01bed8","5f9b6057.091398","c8180dab.5ee6a8"]]},{"id":"8e53a9b5.2fee8","type":"ui_text","z":"ce4bb0dd.a8435","group":"38acb3ef.21ae24","order":1,"width":0,"height":0,"name":"","label":"Sensor 1","format":"{{msg.name}}","layout":"col-center","className":"","x":1240,"y":360,"wires":[]},{"id":"707583ce.97b974","type":"ui_gauge","z":"ce4bb0dd.a8435","name":"","group":"38acb3ef.21ae24","order":2,"width":0,"height":0,"gtype":"gage","title":"","label":"","format":"{{value | number:1}} ","min":0,"max":"100","colors":["#005cb3","#e6b400","#ca3838"],"seg1":"","seg2":"","className":"","x":1230,"y":400,"wires":[]},{"id":"c8180dab.5ee6a8","type":"function","z":"ce4bb0dd.a8435","name":"","func":"\nmsg = {ui_control:{min:msg.payload.Min}};\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1020,"y":400,"wires":[["707583ce.97b974"]]},{"id":"5f9b6057.091398","type":"function","z":"ce4bb0dd.a8435","name":"","func":"\nmsg = {ui_control:{max:msg.payload.Max}};\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1020,"y":360,"wires":[["707583ce.97b974"]]},{"id":"72064ba4.9c14bc","type":"change","z":"ce4bb0dd.a8435","name":"Sensor 1","rules":[{"t":"set","p":"payload","pt":"msg","to":"AI00.value","tot":"global"},{"t":"set","p":"name","pt":"msg","to":"AI00.name","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":1020,"y":280,"wires":[["8e53a9b5.2fee8","707583ce.97b974"]]},{"id":"f95b453c.b2d438","type":"function","z":"ce4bb0dd.a8435","name":"Style Gauge","func":"var name = msg.payload;\n\nif (name == \"Druk\"){\n msg.ui_control = \n {\n \"gtype\": \"donut\",\n \"options\":{\n \"circleColor\": msg.circleColor, \n \"textColor\": msg.textColor, \n \"waveTextColor\": msg.waveTextColor, \n \"waveColor\": msg.waveColor, \n \"circleThickness\":0.06, \n \"textVertPosition\":0.4, \n \"waveHeight\":0.08, \n \"waveCount\":3,\n \"label\": \"mbar\",\n }\n }\n \n}else if (name == \"Temperatuur\"){ \n msg.ui_control = \n {\n \"gtype\": \"gage\",\n \"options\":{\n \"label\": \"°c\",\n }\n }\n} else if (name ==\"Geleidbaarheid\"){\n msg.ui_control =\n {\n \"gtype\": \"donut\",\n \"options\":{\n \"label\": \"µS\",\n }\n \n }\n} else if (name ==\"Flow\"){\n msg.ui_control =\n {\n \"gtype\": \"gage\",\n \"options\":{\n \"label\": \"m/s\",\n }\n \n }\n} else {\n msg.ui_control =\n {\n \"gtype\": \"\",\n \"options\":{\n \"label\": \"\",\n \"max\": 0,\n }\n }\n msg.name = \"empty\";\n}\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1010,"y":320,"wires":[["707583ce.97b974","8e53a9b5.2fee8"]]},{"id":"2caba41f.e07d84","type":"link out","z":"ce4bb0dd.a8435","name":"Flow_Name","links":["b5ffb334.371da8"],"x":525,"y":40,"wires":[]},{"id":"b5ffb334.371da8","type":"link in","z":"ce4bb0dd.a8435","name":"","links":["2caba41f.e07d84"],"x":895,"y":280,"wires":[["f95b453c.b2d438"]]},{"id":"abcb8328.96141","type":"ui_group","z":"","name":"Settings","tab":"58a80602.fb5da8","order":1,"disp":true,"width":19,"collapse":false,"className":""},{"id":"38acb3ef.21ae24","type":"ui_group","z":"","name":"Sensor 1","tab":"b8864e65.57ebf","order":2,"disp":true,"width":"10","collapse":true,"className":""},{"id":"58a80602.fb5da8","type":"ui_tab","z":"","name":"Sensoren","icon":"perm_data_setting","order":3,"disabled":false,"hidden":false},{"id":"b8864e65.57ebf","type":"ui_tab","z":"","name":" Dashboard","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
