Receiving mqtt from multiple TTN applications
Hello everyone, I’m trying to receive sensors data that comes from different applications
using MQTT integration and Node-Red, the issue that I’m facing is that extracting only one
application is working fine and I can receive the data from that one application.
when I try to add another “mqtt in” node to receive the data from another application, just
after configuring the tenant id and password for the new application and suddenly the older
mqtt-in node automatically change its server to the new application and it starts to receive the
same data from the new application
also using the Subscribing API that TTN provides :
“v3/{application id}@{tenant id}/devices/{device id}/up” as a topic makes the node receives
nothing from TTN. kindly help, how can I set the configuration of the mqtt in order to receive
from many applications at the same time?
You can add multiple mqtt configs that way changing the details of one does not affect the other.
would you elaborate more please, this is how my flow looks like:
whenever I change the configuration on one of the mqtt-in nodes of one, all the others
changes and I keep receiving the same message from all the MQTT-in nodes instead of
receiving different application payloads.
As I said...
Thank you so much Steve that solve the issue.
