Recommend a singe smart outlet turned on/off with Node Red?
I have a shed. In that shed is the router with my network. I'd like to plug some smart device into the router that has an IP address that Node Red can send on/off commands to. That smart device would then wirelessly turn on or off a 120V plug in the same shed.
Can anyone recommend a device / smart outlet that would fit the bill?
Are you looking for wired or wireless? Wireless gives you more options I think.
Wi-Fi and Zigbee wireless solutions are the most common. But in this specific case, Bluetooth might even be ok.
Of course, you will need to make sure that you actually have a method of turning the plug back on again. No good if your Node-RED and other servers are running off the same powerpoint. :smile:
Tasmota Relay?
https://aliexpress.com/item/1005007607785126.html
A Tasmota smart socket is a good suggestion. If you are in the US I suggest Athom since they can be bought with Tasmota firmware, which works very well with Node-red & MQTT
(There is a v3 too, don't know what the difference is)
A Tasmota device connects to your wifi.
You can give it an MQTT topic eg "tasmota/shed" and then you can control it by publishing "ON" or "OFF" to that topic.
Tasmota devices send regular status messages too, including relay state and sometimes power consumption data.
I think wireless for this one. Fortunately my Node Red and network stuff won't be running off the same power source.
Thank you both for the suggestion, that looks like it will fit the bill and that will come in handy. Appreciate ya!
I use the Kasa HS-103 (wifi) and the node-red-contrib-tplink (node) - Node-RED nodes. Control via Node-RED is local (IP based) and the advantage is that you can also control it via the Kasa app over the internet
TP-Link-Kasa-Smart-Wifi-Plug
I am very pleased with all my Shelly devices (among other the Shelly Plug S). They run on wifi and support mqtt.
I see the 'Matter' compatible smart plugs are now available at good prices.
