Hi folks,
I'm currently developing a node which contains following endpoint:
RED.httpAdmin.get('/xterm_shell/:node_id/:terminal_id/:command/:info', function(req, res) {
var xtermShellNode = RED.nodes.getNode(req.params.node_id);
The config screen call this endpoint and passes it's node_id in the URL.
Normally I only work on Raspberry, and on Raspberry it works fine!! The RED.nodes.getNode returns the specified node instance, so I can do my stuff ...
However this node needs to do some specific stuff on Windows, so I have tested this on my Windows 10 portable. But there the function returns null:
The node id is passed correctly by the client via the URL:
This corresponds exactly to the node id in my flow editor:
So I hoped to find something more by debugging into the
RED.nodes.getNode, but there all arrays are empty for some reason:
And I think my versions are quite correct:
17 Nov 19:11:51 - [info] Node-RED version: v1.0.2
17 Nov 19:11:51 - [info] Node.js version: v10.15.3
Does anybody have a tip?
Thanks,
Bart
