Hi guys, I want a scheduler to run every 1 hour, on every day, so which build-in node , i should go , whether i need to use schedex / inject /scheduler/light scheduler ? , how to use these nodes
The only built-in core node that you mentioned is Inject.
I'm guessing the others you mention are contrib nodes that you have installed.
As the Inject node can do what you want I'd suggest using that one.
if in case , I use inject node, for every one hour, then what I should give in "between" field and
"and" field, please suggest me
Why not just use the interval option?
, I want to run all the 7 days, for every 1 hour , so, If I use just interval option, will this scheduler run for all the 7 days??
It will run every 60 minutes.
Ok thanks
