Why are the msg.socketIp outputs from the UI control node and event node all 'undefined'?
You should find them in _client property, use a debug node set to complete message object to see all properties. There is also a setting in the dashboard sidebar for this also Getting Started | Node-RED Dashboard 2.0 & Getting Started | Node-RED Dashboard 2.0.
Else provide an example flow demonstrating your issue.
In fact _client does not appear to be there.
Thank you for your guidance. It is indeed because I did not notice '_cient'.
Oh, I had forgotten about the setting for client data, I see it now too.
