Regurgitated message ID's when using Download FTP node
When downloding files from an FTP site using node-red-contrib-ftp-download (node) - Node-RED node The 1st time it is run I get a meaasge, the 2nd time it runs I get 2 messsges, a repeat of the 1st one and a new one for the 2nd run. Run the flow a 3rd time and I get a 3rd copy of the 1st message, a 2nd copy of the 2nd message and a new 3rd message.
It seems to cache the previous messages and regurgitate them.
See screen recording and below image.
Any ideas why this behaviour is seen
This example is using rebix test https://test.rebex.net/ but I get exactly the same behaviour from our internal server
Flow script below
[{"id":"e8a6870e46d12ef8","type":"advanced-ftp","z":"e5989d7ff278b3f6","ftp":"c1d364c1b06ff603","operation":"list","dataType":"binary","filename":"","localFilename":"","workingDir":"/pub/example","oldPath":"","newPath":"","command":"","recursive":false,"useCompression":false,"throwError":true,"showError":true,"name":"List files in Outbound","x":500,"y":900,"wires":[["2f75b21051691173"]]},{"id":"484bc807c69d332b","type":"inject","z":"e5989d7ff278b3f6","name":"Download NB PO","props":[{"p":"payload"},{"p":"tsStart","v":"","vt":"date"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":900,"wires":[["e8a6870e46d12ef8"]]},{"id":"2f75b21051691173","type":"split","z":"e5989d7ff278b3f6","name":"Split the FTP file array","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":183,"y":1000,"wires":[["72169bb43ea58d77"]]},{"id":"72169bb43ea58d77","type":"switch","z":"e5989d7ff278b3f6","name":"Identify the files we need","property":"payload.name","propertyType":"msg","rules":[{"t":"cont","v":"KeyGen","vt":"str"},{"t":"nempty"}],"checkall":"false","repair":false,"outputs":2,"x":493,"y":1000,"wires":[["fb6544f1f05a4d78"],["5004b4ca22be0d0f"]]},{"id":"fb6544f1f05a4d78","type":"function","z":"e5989d7ff278b3f6","name":"Move filename to payload for join","func":"msg.payload = msg.payload.name;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":220,"y":1080,"wires":[["f266bf2336834da7"]]},{"id":"5004b4ca22be0d0f","type":"function","z":"e5989d7ff278b3f6","name":"Assigns NA for later filtering","func":"msg.payload='NA';\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":200,"y":1140,"wires":[["f266bf2336834da7"]]},{"id":"f266bf2336834da7","type":"join","z":"e5989d7ff278b3f6","name":"","mode":"auto","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":470,"y":1100,"wires":[["3c191f23b601d3f8"]]},{"id":"3c191f23b601d3f8","type":"function","z":"e5989d7ff278b3f6","name":"Filter out the files we need","func":"var filtArr = msg.payload;\n\n//const retArr = filtArr.filter(filterFiles)\nconst tmpArr = filtArr.filter(filterFiles)\nconst retArr = tmpArr.map(filepaths);\n\n//let retObj = [];\n\n// for (let i = 0; i < retArr.length; i++) {\n//   //obj[i] = arr[i];\n//   let srcfile = '/outbound/archive/' + retArr[i];\n//   let destfile = '/media/share/sftpSAPTest/NB-SAP/Inbound/Staging' + retArr[i];\n//   let cc = {'src':srcfile, 'dest':destfile};\n//   retObj.push(cc);\n// }\n\n// msg.test = retObj;\n//msg.filesToDownload = retArr;\nmsg.payload = retArr;\n\n\nreturn msg;\n\n\nconst arrayToObject = (arr) => {\n  let obj = {};\n  for (let i = 0; i < arr.length; i++) {\n    obj[i] = arr[i];\n  }\n  return obj;\n};\n\n\nfunction filterFiles(fname){\n  return fname != 'NA';\n}\nfunction filepaths(fname) {\n  return '/pub/example/' + fname;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":190,"y":1200,"wires":[["10cd70d1b1b5364c"]]},{"id":"10cd70d1b1b5364c","type":"ftp-download","z":"e5989d7ff278b3f6","server":"a0654230a6945c41","files":"payload","directory":"/media/share/sftpSAPTest/NB-SAP/Inbound/Staging/","name":"Download the files","output":"payload","filesType":"msg","directoryType":"str","x":430,"y":1200,"wires":[["df1620b04cd1b369"]]},{"id":"df1620b04cd1b369","type":"debug","z":"e5989d7ff278b3f6","name":"debug 124","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":670,"y":1140,"wires":[]},{"id":"c1d364c1b06ff603","type":"advanced-ftp-config","host":"test.rebex.net","port":"","secure":false,"secureOptions":"","user":"demo","connTimeout":"","pasvTimeout":"","keepalive":"","name":""},{"id":"a0654230a6945c41","type":"ftp-download-server","host":"test.rebex.net","port":"21","user":"demo","connTimeout":"10000","pasvTimeout":"10000","keepalive":"10000","name":""}]
PS. If I disable the download node and wire the massage to the "Filter Out files we need" function node, I only ever get 1 message returned, so defo teh download node forcing teh regurgitation.
Looking at the flow, it tries to connects but comes back with an error: but it still goes through the split node and there is where the messages come from. Check what the output of the split node produces when it is unable to connect. Perhaps you should use a switch node in front of the split node and only let messages pass if they are valid (eg. has a filename) and not in error.
Hi
Thanks for the reply
Even without the error (i.e. when using an internal FTP server) the message still gets regurgitated. The error comes from me using a public service to demo the issue.
The below image shows the results when connected to our internal server. You see that the for the 1st run the 1st message, ID 66226535b6667158 @ 2/10/2023, 8:12:25 am (we're in NZ so UTC + 12) has a timestamp of 1696187528042. When run a second time, this message is resent but @ 2/10/2023, 8:13:13 am and a new message for the 2nd Run ID 2a76034c54d49958 with timestamp 1696187563241.
When run a 3rd time we get message 66226535b6667158 a 3rd time, message 2a76034c54d49958 a second time and a new for the 3rd run.
As mentioned before, if I wire the debug:125 node to the function prior to the Download Files node, I only ever get 1 message per run.
So it appears that the download files is "caching" the messages, resending them and then appending a new one on each subsequent run.
