Can I disable or remove the [delete] button of the mine node?
no you cannot.
Thanks!! Some of my nodes are [Global configuration nodes] so I don't want users to delete them
If a user decides not to use your nodes anymore what do they do?
On my system, these nodes are the default. If the user doesn't use it then they can't do anything with other operations, the user also cannot edit the config values
