Renaming array elements after join
I have joined two payloads to an array.
How would one replace the array element numbers to a custom string?
I tried using the change node and move payloads, without success.
An array has numeric indices.
Can't you set the join node to create a key/value object?
The resulting object would use msg.topic as the element names
You are right. I did try, but did not use msg.topic in the change node. It works now. Thanks!
