This is just a screenshot of a control I need in the dashboard:
The problem is that I have 27 devices which need this control on the dashboard. Isn't there any other way but to copy and paste 27 times this flow on the same page? I will go crazy in that case...
better get some good medication then...
Seriously? So I can't have my beautiful synoptic table for all my ui-switches and devices?
There is some work being looked at to enable ui nodes to exist in subflows properly. You would then be able to put your flows into a subflow and then an instance of the subflow for each device.
However I don't know when that work will be made available.
So yes, in the meantime, you'll have to copy and paste a lot of flows.
