REST API Node POST for ETA SH heating system
Deare
can anyone help me please
I want to set an Value on my ETA Touch heating system, via Rest api
with; (http://192.168.178.22:8080/user/var//120/10281/0/0/12080)
i get this value
1802
how must look the flow to set the Value to 1802`?
thank you für your help
Is this the product you have? https://www.meineta.at/javax.faces.resource/downloads/ETA-RESTful-v1.2.pdf.xhtml?ln=default&v=0
Can you share the flow that you have created thus far (which returns 1802) with this forum> Please take care to format it properly so that it is displayed correctly.
The easiest way to do that is to click the 'Preformatted Text' button in the toolbar:
Then paste in your code or flow json.
You should end up with three back-tick characters - ````` - on their own line before and after the code.
Dear Grant
yes thats my ETA Touch heating system
currently thats the flow....
        "id": "582746de21977bac",
        "type": "tab",
        "label": "Flow 5",
        "disabled": false,
        "info": "",
        "env": []
        "id": "e37466e86c55c175",
        "type": "inject",
        "z": "582746de21977bac",
        "name": "Get values every 10s",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "60",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 100,
        "y": 280,
                "08b052733c807818"
        "id": "08b052733c807818",
        "type": "http request",
        "name": "Brenner",
        "method": "GET",
        "ret": "txt",
        "paytoqs": "ignore",
        "url": "http://192.168.178.22:8080/user/var//120/10281/0/0/12080",
        "tls": "",
        "persist": false,
        "proxy": "",
        "insecureHTTPParser": false,
        "authType": "",
        "senderr": false,
        "headers": [],
        "x": 320,
        "y": 280,
                "e759fbf968a9083b"
        "id": "e759fbf968a9083b",
        "type": "xml",
        "property": "payload",
        "attr": "",
        "chr": "",
        "x": 530,
        "y": 280,
                "57b7a318cd8b70ed"
        "id": "57b7a318cd8b70ed",
        "type": "function",
        "name": "test",
        "func": "msg.payload = msg.payload.eta.value[0].$.strValue\nmsg.payload = msg.payload.replace(\",\" , \".\");\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 710,
        "y": 280,
                "f26ac32cfc54e3f9"
        "id": "f26ac32cfc54e3f9",
        "type": "function",
        "name": "test",
        "func": "node.status({fill:\"blue\",shape:\"ring\",text:msg.payload });   \n\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 890,
        "y": 280,
[Moderator edit to fix code formating]
