Is it possible to revert a node module to an older version? I've installed node-RED using the recommended script. Updated node-red-node-email to 1.8.3 today and my attachments are no longer working as they were with the previous version.
Hi @Ashfaak
from the command-line, you can run npm install node-red-node-email@<version> when you are in the ~/.node-red directory and replacing <version> with the version of the module you want to install.
Have you reported the issue anywhere so it can be investigated?
Hi @knolleary
Thanks for the swift reply. I actually tried that, but in the wrong folder
Then I tried it again in the correct folder but did not restart NR.
I was about to add an issue on Github but it says to mention the issue here or on Slack first. The way this query is formed probably doesn't help much - I will add more info here:
Refer to this commit: https://github.com/node-red/node-red-nodes/commit/14983c9722743369c11305cb79fdd1d96dd70ea6
My msg.attachments is formed like this in Jsonata: { "href":"https://drive.google.com/uc?export=download&id=" &req.params.fileid, "filename" : payload.filename }
It is not array so it fails to become sendopts.attachments.
Attachments work again by setting msg.attachments to an array.
