I try to control my 433MHz wall plugs from Node-RED with a RFXcom.
Have added node-red-contrib-rfxcom and have set up the out-node.
But the rfx-light node will not get connected
What can be wrong?
What can be wrong?
Is the port in use already?
Did you enter correct settings in the serial port config?
Are you running node-red in docker or a container?
Is the account running node-red a member of dialout group?
I don't think that the port is used by something else.
Serial port config, were is that?
It look correct to me.
From the HA hardware-list I have this
Same port as I have configured in the rfx-light node
The funny thing is that some times it get's connected after system reboot it gets connected.
But most of the times it want connect.
ok, so this is a Home Assistant install of node-red - i.e. contained
You will possibly need to head over to the HA forum and search for "serial port" since I have no idea how HA maps devices or the accounts they use etc.
Also, you might want to check out the repository - there may be known issues or workarounds already discussed; Issues · maxwellhadley/node-red-contrib-rfxcom · GitHub
