I said...
I update the NR.
Then i install the riot project. Can't upload the whole report because it is too big
/home/pi/.cache/node-gyp/12.18.4/include/node/node.h:642:3: note: in expansion of macro โNODE_MODULE_Xโ
NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
../fs-ext.cc:572:3: note: in expansion of macro โNODE_MODULEโ
NODE_MODULE(fs_ext, init)
make: *** [fs-ext.target.mk:109: Release/obj.target/fs-ext/fs-ext.o] Error 1
make: Leaving directory '/home/pi/.node-red/node_modules/fs-ext/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! stack at ChildProcess.emit (events.js:315:20)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
gyp ERR! System Linux 5.4.51-v7l+
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"
gyp ERR! cwd /home/pi/.node-red/node_modules/fs-ext
gyp ERR! node -v v12.18.4
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm WARN node-red-contrib-ui-led@0.3.3 requires a peer of node-red-dashboard@2.23.x but none is installed. You must install peer dependencies yourself.
npm WARN tsutils@3.17.1 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/zigbee-herdsman/node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.2.1 (node_modules/bufferutil):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.2.1 install: `node-gyp rebuild`
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fs-ext@0.5.0 (node_modules/fs-ext):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fs-ext@0.5.0 install: `node-gyp configure build`
+ riot-xbee@0.0.1
added 1 package and audited 1982 packages in 75.444s
65 packages are looking for funding
run `npm fund` for details
found 353 vulnerabilities (73 low, 68 moderate, 211 high, 1 critical)
run `npm audit fix` to fix them, or `npm audit` for details
pi@raspberrypi:~/.node-red $
Then try to run NR and it stuck in to some cycle
Starting as a systemd service.
10 Jul 20:23:38 - [info]
Welcome to Node-RED
10 Jul 20:23:38 - [info] Node-RED version: v1.3.5
10 Jul 20:23:38 - [info] Node.js version: v12.18.4
10 Jul 20:23:38 - [info] Linux 5.4.51-v7l+ arm LE
10 Jul 20:23:39 - [info] Loading palette nodes
10 Jul 20:23:48 - [info] Dashboard up and running
10 Jul 20:23:52 - [info] Dashboard version 2.20.0 started at /ui
10 Jul 20:23:52 - [warn] ------------------------------------------------------
10 Jul 20:23:52 - [warn] [node-red-contrib-usb/adkinit] SyntaxError: Invalid or unexpected token (line:59)
10 Jul 20:23:52 - [warn] [node-red-contrib-mqtt-env/mqtt-env] Error: Cannot find module '/usr/lib/node_modules/node-red/red/red'
Require stack:
- /home/pi/.node-red/node_modules/node-red-contrib-mqtt-env/lib/mqttConnectionPool.js
- /home/pi/.node-red/node_modules/node-red-contrib-mqtt-env/mqtt-env.js
- /usr/lib/node_modules/node-red/node_modules/@node-red/registry/lib/loader.js
- /usr/lib/node_modules/node-red/node_modules/@node-red/registry/lib/index.js
- /usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/index.js
- /usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/index.js
- /usr/lib/node_modules/node-red/lib/red.js
- /usr/lib/node_modules/node-red/red.js
10 Jul 20:23:52 - [warn] [node-red-contrib-mqttssl/mqttssl] Error: Cannot find module '/usr/lib/node_modules/node-red/red/red'
Require stack:
- /home/pi/.node-red/node_modules/node-red-contrib-mqttssl/lib/mqttClientPool.js
- /home/pi/.node-red/node_modules/node-red-contrib-mqttssl/mqttssl.js
10 Jul 20:23:52 - [warn] [node-red-qnap-blockly/blockly] Type already registered
10 Jul 20:23:52 - [warn] [riot-xbee/riot-xbee] Error: Cannot find module '/home/pi/.node-red/node_modules/riot-xbee/riot-xbee.js'
Require stack:
10 Jul 20:23:52 - [info] Settings file : /home/pi/.node-red/settings.js
10 Jul 20:23:52 - [info] Context store : 'default' [module=memory]
10 Jul 20:23:52 - [info] User directory : /home/pi/.node-red
10 Jul 20:23:52 - [warn] Projects disabled : editorTheme.projects.enabled=false
10 Jul 20:23:52 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
10 Jul 20:23:52 - [red] Uncaught Exception:
10 Jul 20:23:52 - Error: listen EADDRINUSE: address already in use 0.0.0.0:1880
at Server.setupListenHandle [as _listen2] (net.js:1313:16)
at listenInCluster (net.js:1361:12)
at doListen (net.js:1498:7)
at processTicksAndRejections (internal/process/task_queues.js:85:21)
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Failed with result 'exit-code'.
nodered.service: Service RestartSec=20s expired, scheduling restart.
nodered.service: Scheduled restart job, restart counter is at 11.
Stopped Node-RED graphical event wiring tool.
10 Jul 20:24:14 - [info]
Welcome to Node-RED
Why are you using node-red-contrib-mqttssl?
Uninstall it. It is nearly 7 years old. Use the built in MQTT nodes.
I used npm remove node-red-contrib-mqttssl, correct?
i have this
10 Jul 21:06:26 - [info]
Welcome to Node-RED
10 Jul 21:06:26 - [info] Node-RED version: v1.3.5
10 Jul 21:06:26 - [info] Node.js version: v12.18.4
10 Jul 21:06:26 - [info] Linux 5.4.51-v7l+ arm LE
10 Jul 21:06:27 - [info] Loading palette nodes
10 Jul 21:06:36 - [info] Dashboard up and running
10 Jul 21:06:39 - [info] Dashboard version 2.20.0 started at /ui
10 Jul 21:06:40 - [warn] ------------------------------------------------------
10 Jul 21:06:40 - [warn] [node-red-contrib-usb/adkinit] SyntaxError: Invalid or unexpected token (line:59)
10 Jul 21:06:40 - [warn] [node-red-contrib-mqtt-env/mqtt-env] Error: Cannot find module '/usr/lib/node_modules/node-red/red/red'
Require stack:
10 Jul 21:06:40 - [warn] [node-red-contrib-mqttssl/mqttssl] Error: Cannot find module '/usr/lib/node_modules/node-red/red/red'
Require stack:
10 Jul 21:06:40 - [warn] [node-red-qnap-blockly/blockly] Type already registered
10 Jul 21:06:40 - [warn] [riot-xbee/riot-xbee] Error: Cannot find module '/home/pi/.node-red/node_modules/riot-xbee/riot-xbee.js'
Require stack:
10 Jul 21:06:40 - [info] Settings file : /home/pi/.node-red/settings.js
10 Jul 21:06:40 - [info] Context store : 'default' [module=memory]
10 Jul 21:06:40 - [info] User directory : /home/pi/.node-red
10 Jul 21:06:40 - [warn] Projects disabled : editorTheme.projects.enabled=false
10 Jul 21:06:40 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
10 Jul 21:06:40 - [red] Uncaught Exception:
10 Jul 21:06:40 - Error: listen EADDRINUSE: address already in use 0.0.0.0:1880
nodered.service: Scheduled restart job, restart counter is at 83.
10 Jul 21:07:02 - [info]
Welcome to Node-RED
It is still there. You Also need to get rid of node-red-contrib-mqtt-env
Did you npm uninstall from the ~/.node-red folder?
cd ~/.node-red
npm uninstall node-red-contrib-mqtt-env
npm uninstall node-red-contrib-mqttssl
sudo npm uninstall -g node-red-contrib-mqtt-env
sudo npm uninstall -g node-red-contrib-mqttssl
I uninstall, then try this
And got this
pi@raspberrypi:~ $ cd ~/.node-red
pi@raspberrypi:~/.node-red $ sudo npm uninstall -g node-red-contrib-mqtt-env
up to date in 0.169s
pi@raspberrypi:~/.node-red $ sudo npm uninstall -g node-red-contrib-mqttssl
up to date in 0.181s
โญโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโฎ
โ โ
โ New major version of npm available! 6.14.6 โ 7.19.1 โ
โ Changelog: https://github.com/npm/cli/releases/tag/v7.19.1 โ
โ Run npm install -g npm to update! โ
โ โ
โฐโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโฏ
And again this
10 Jul 21:38:29 - [info]
Welcome to Node-RED
10 Jul 21:38:29 - [info] Node-RED version: v1.3.5
10 Jul 21:38:29 - [info] Node.js version: v12.18.4
10 Jul 21:38:29 - [info] Linux 5.4.51-v7l+ arm LE
10 Jul 21:38:30 - [info] Loading palette nodes
10 Jul 21:38:38 - [info] Dashboard up and running
10 Jul 21:38:42 - [info] Dashboard version 2.20.0 started at /ui
10 Jul 21:38:43 - [warn] ------------------------------------------------------
10 Jul 21:38:43 - [warn] [node-red-contrib-usb/adkinit] SyntaxError: Invalid or unexpected token (line:59)
10 Jul 21:38:43 - [warn] [node-red-qnap-blockly/blockly] Type already registered
10 Jul 21:38:43 - [warn] [riot-xbee/riot-xbee] Error: Cannot find module '/home/pi/.node-red/node_modules/riot-xbee/riot-xbee.js'
Require stack:
10 Jul 21:38:43 - [warn] Missing node modules:
10 Jul 21:38:43 - [warn] - node-red-contrib-mqtt-env (1.0.0): mqtt-env in, mqtt-env out, mqtt-env-broker
10 Jul 21:38:43 - [warn] - node-red-contrib-mqttssl (0.0.5): mqttssl in, mqttssl out, mqttssl-broker
10 Jul 21:38:43 - [info] Removing modules from config
10 Jul 21:38:43 - [info] Settings file : /home/pi/.node-red/settings.js
10 Jul 21:38:43 - [info] Context store : 'default' [module=memory]
10 Jul 21:38:43 - [info] User directory : /home/pi/.node-red
10 Jul 21:38:43 - [warn] Projects disabled : editorTheme.projects.enabled=false
10 Jul 21:38:43 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
10 Jul 21:38:43 - [red] Uncaught Exception:
10 Jul 21:38:43 - Error: listen EADDRINUSE: address already in use 0.0.0.0:1880
nodered.service: Scheduled restart job, restart counter is at 136.
10 Jul 21:39:05 - [info]
Welcome to Node-RED
Missing node modules: 10 Jul 21:38:43 - [warn] - node-red-contrib-mqtt-env (1.0.0): mqtt-env in, mqtt-env out, mqtt-env-broker 10 Jul 21:38:43 - [warn] - node-red-contrib-mqttssl
So now start node-red in safe mode (as you were shown before) and remove missing nodes and deploy.
Note, these nodes can be replaced with built in mqtt nodes.
Note also, they might be config nodes in the right sidebar (not necessarily on the editor tabs)
Uncaught Exception: 10 Jul 21:38:43 - Error: listen EADDRINUSE: address already in use 0.0.0.0:1880
This means node-red is already running.
Use node-red-stop to stop node-red service.
You did not run the right command to uninstall the modules.
In the .node-red directory run npm uninstall <module-name> without sudo and without the -g option.
-goption.
I asked him to do both nick (incase an old global install had been done)
cd ~/.node-red npm uninstall node-red-contrib-mqtt-env npm uninstall node-red-contrib-mqttssl sudo npm uninstall -g node-red-contrib-mqtt-env sudo npm uninstall -g node-red-contrib-mqttssl
Yes, you asked him to do that, but the console output he shared shows he didn't.
I did everything you told me.
I stop NR, but when I call it from a browser it still pop-up?
What you mean by safe mode?
How to do the replacement with built in mqtt nodes?
Stop node-red
node-red-stop
Start in safe mode
node-red --safe
Open node-red in browser
Use Search ctrl-f and search for all instances of...
- mqtt-env
- mqttssl
Delete them all, deploy.
Even when i stop the NR i still can load it from Browser, is it normal?
By using Search (ctrl-f) for all instances of mqtt-env and mqtt ssl, i don't find them.
When i use node-red --safe, i've got this:
pi@raspberrypi:~ $ node-red --safe
11 Jul 13:55:28 - [info]
Welcome to Node-RED
11 Jul 13:55:28 - [info] Node-RED version: v1.3.5
11 Jul 13:55:28 - [info] Node.js version: v12.18.4
11 Jul 13:55:28 - [info] Linux 5.4.51-v7l+ arm LE
11 Jul 13:55:29 - [info] Loading palette nodes
11 Jul 13:55:52 - [info] Dashboard up and running
11 Jul 13:55:56 - [info] Dashboard version 2.20.0 started at /ui
11 Jul 13:55:56 - [warn] ------------------------------------------------------
11 Jul 13:55:56 - [warn] [node-red-contrib-usb/adkinit] SyntaxError: Invalid or unexpected token (line:59)
11 Jul 13:55:56 - [warn] [node-red-qnap-blockly/blockly] Type already registered
11 Jul 13:55:56 - [warn] [riot-xbee/riot-xbee] Error: Cannot find module '/home/pi/.node-red/node_modules/riot-xbee/riot-xbee.js'
Require stack:
11 Jul 13:55:56 - [warn] Missing node modules:
11 Jul 13:55:56 - [warn] - node-red-contrib-mqtt-env (1.0.0): mqtt-env in, mqtt-env out, mqtt-env-broker
11 Jul 13:55:56 - [warn] - node-red-contrib-mqttssl (0.0.5): mqttssl in, mqttssl out, mqttssl-broker
11 Jul 13:55:56 - [info] Removing modules from config
11 Jul 13:55:56 - [info] Settings file : /home/pi/.node-red/settings.js
11 Jul 13:55:56 - [info] Context store : 'default' [module=memory]
11 Jul 13:55:56 - [info] User directory : /home/pi/.node-red
11 Jul 13:55:56 - [warn] Projects disabled : editorTheme.projects.enabled=false
11 Jul 13:55:56 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
11 Jul 13:55:57 - [red] Uncaught Exception:
11 Jul 13:55:57 - Error: listen EADDRINUSE: address already in use 0.0.0.0:1880
pi@raspberrypi:~ $
When i run NR via Start-Programming, i've got this similar cycle like before
11 Jul 14:13:44 - [info]
Welcome to Node-RED
11 Jul 14:13:44 - [info] Node-RED version: v1.3.5
11 Jul 14:13:44 - [info] Node.js version: v12.18.4
11 Jul 14:13:44 - [info] Linux 5.4.51-v7l+ arm LE
11 Jul 14:13:45 - [info] Loading palette nodes
11 Jul 14:13:54 - [info] Dashboard up and running
11 Jul 14:13:58 - [info] Dashboard version 2.20.0 started at /ui
11 Jul 14:13:58 - [warn] ------------------------------------------------------
11 Jul 14:13:58 - [warn] [node-red-contrib-usb/adkinit] SyntaxError: Invalid or unexpected token (line:59)
11 Jul 14:13:58 - [warn] [node-red-qnap-blockly/blockly] Type already registered
11 Jul 14:13:58 - [warn] [riot-xbee/riot-xbee] Error: Cannot find module '/home/pi/.node-red/node_modules/riot-xbee/riot-xbee.js'
Require stack:
11 Jul 14:13:58 - [warn] Missing node modules:
11 Jul 14:13:58 - [warn] - node-red-contrib-mqtt-env (1.0.0): mqtt-env in, mqtt-env out, mqtt-env-broker
11 Jul 14:13:58 - [warn] - node-red-contrib-mqttssl (0.0.5): mqttssl in, mqttssl out, mqttssl-broker
11 Jul 14:13:58 - [info] Removing modules from config
11 Jul 14:13:58 - [info] Settings file : /home/pi/.node-red/settings.js
11 Jul 14:13:58 - [info] Context store : 'default' [module=memory]
11 Jul 14:13:58 - [info] User directory : /home/pi/.node-red
11 Jul 14:13:58 - [warn] Projects disabled : editorTheme.projects.enabled=false
11 Jul 14:13:58 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
11 Jul 14:13:58 - [red] Uncaught Exception:
11 Jul 14:13:58 - Error: listen EADDRINUSE: address already in use 0.0.0.0:1880
nodered.service: Scheduled restart job, restart counter is at 1.
11 Jul 14:14:20 - [info]
Welcome to Node-RED
This means node-red is still running.
for clarification
when you install using the official script, it creates a service runner for node-red. It also provides 3 helper commands...
node-red-start- start node-red as a background servicenode-red-stop- stop node-red servicenode-red-log- show log of running service
When you type node-red or node-red --safe it starts up ANOTHER node-red (and therefore the error seen above)
Do the following..
- Stop node-red service:
node-red-stop - Stop any other node-red running in a terminal ctrl+c
- Start in safe mode:
node-red --safe - Open node-red in browser
- Use Search ctrl-f and search for all instances of...
- mqtt-env
- mqttssl
Delete them all
- deploy.
Once node-red is running normally, you can quit the terminal version (ctrl+c) and restart the node-red service node-red-start
I try again, but can't stop NR
Type in ps -A | grep node-red
then you will see any process IDs for node-red, then you can kill it with kill xxxx where xxxx is the PID
e.g...
As I said before, if you dont press the reply attached to my comment, i dont know you have replied.
Did you start node-red as an sudo?
do sudo kill 2926
I think it still running
pi@raspberrypi:~ $ ps -A | grep node-red
2926 ? 00:00:14 node-red
pi@raspberrypi:~ $ kill 2926
bash: kill: (2926) - Operation not permitted
pi@raspberrypi:~ $ sudo kill 2926
pi@raspberrypi:~ $ sudo node-red-stop
Stop Node-RED
Use node-red-start to start Node-RED again
pi@raspberrypi:~ $ sudo node-red-log
11 Jul 14:29:27 - [warn] ------------------------------------------------------
11 Jul 14:29:27 - [warn] Missing node modules:
11 Jul 14:29:27 - [warn] - node-red-contrib-mqtt-env (1.0.0): mqtt-env in, mqtt-env out, mqtt-env-broker
11 Jul 14:29:27 - [warn] - node-red-contrib-mqttssl (0.0.5): mqttssl in, mqttssl out, mqttssl-broker
11 Jul 14:29:27 - [info] Removing modules from config
11 Jul 14:29:27 - [info] Settings file : /home/pi/.node-red/settings.js
11 Jul 14:29:27 - [info] Context store : 'default' [module=memory]
11 Jul 14:29:27 - [info] User directory : /home/pi/.node-red
11 Jul 14:29:27 - [warn] Projects disabled : editorTheme.projects.enabled=false
11 Jul 14:29:27 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
11 Jul 14:29:27 - [red] Uncaught Exception:
11 Jul 14:29:27 - Error: listen EADDRINUSE: address already in use 0.0.0.0:1880
After safe run i've got this
pi@raspberrypi:~ $ sudo node-red --safe
11 Jul 15:25:27 - [info]
Welcome to Node-RED
11 Jul 15:25:27 - [info] Node-RED version: v1.3.5
11 Jul 15:25:27 - [info] Node.js version: v12.18.4
11 Jul 15:25:27 - [info] Linux 5.4.51-v7l+ arm LE
11 Jul 15:25:28 - [info] Loading palette nodes
11 Jul 15:25:29 - [warn] ------------------------------------------------------
11 Jul 15:25:29 - [warn] [riot-xbee/riot-xbee] Error: Cannot find module '/usr/lib/node_modules/riot-nodes-master/riot-xbee.js'
Require stack:
11 Jul 15:25:29 - [info] Settings file : /root/.node-red/settings.js
11 Jul 15:25:29 - [info] Context store : 'default' [module=memory]
11 Jul 15:25:29 - [info] User directory : /root/.node-red
11 Jul 15:25:29 - [warn] Projects disabled : editorTheme.projects.enabled=false
11 Jul 15:25:29 - [info] Flows file : /root/.node-red/flows_raspberrypi.json
11 Jul 15:25:29 - [info] Creating new flow file
your credentials.
11 Jul 15:25:29 - [error] Unable to listen on http://127.0.0.1:1880/
11 Jul 15:25:29 - [error] Error: port in use
pi@raspberrypi:~ $
