Riot-nodes error
I think it still running
pi@raspberrypi:~ $ ps -A | grep node-red
 2926 ?        00:00:14 node-red
pi@raspberrypi:~ $ kill 2926
bash: kill: (2926) - Operation not permitted
pi@raspberrypi:~ $ sudo kill 2926
pi@raspberrypi:~ $ sudo node-red-stop
Stop Node-RED
Use   node-red-start   to start Node-RED again
pi@raspberrypi:~ $ sudo node-red-log
- /usr/lib/node_modules/node-red/node_modules/@node-red/registry/lib/loader.js
- /usr/lib/node_modules/node-red/node_modules/@node-red/registry/lib/index.js
- /usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/index.js
- /usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/index.js
- /usr/lib/node_modules/node-red/lib/red.js
- /usr/lib/node_modules/node-red/red.js
11 Jul 14:29:27 - [warn] ------------------------------------------------------
11 Jul 14:29:27 - [warn] Missing node modules:
11 Jul 14:29:27 - [warn]  - node-red-contrib-mqtt-env (1.0.0): mqtt-env in, mqtt-env out, mqtt-env-broker
11 Jul 14:29:27 - [warn]  - node-red-contrib-mqttssl (0.0.5): mqttssl in, mqttssl out, mqttssl-broker
11 Jul 14:29:27 - [info] Removing modules from config
11 Jul 14:29:27 - [info] Settings file  : /home/pi/.node-red/settings.js
11 Jul 14:29:27 - [info] Context store  : 'default' [module=memory]
11 Jul 14:29:27 - [info] User directory : /home/pi/.node-red
11 Jul 14:29:27 - [warn] Projects disabled : editorTheme.projects.enabled=false
11 Jul 14:29:27 - [info] Flows file     : /home/pi/.node-red/flows_raspberrypi.json
11 Jul 14:29:27 - [red] Uncaught Exception:
11 Jul 14:29:27 - Error: listen EADDRINUSE: address already in use 0.0.0.0:1880
    at Server.setupListenHandle [as _listen2] (net.js:1313:16)
    at listenInCluster (net.js:1361:12)
    at doListen (net.js:1498:7)
    at processTicksAndRejections (internal/process/task_queues.js:85:21)
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Failed with result 'exit-code'.
Stopped Node-RED graphical event wiring tool
after you (try) to stop node-red, can you check ps -A | grep node-red again.
node-red-log will show you last logs - doesnt mean it is running
↑ look at the last line
What does ps -A | grep node-red show now?
21338 ?        00:00:09 node-red
pi@raspberrypi:~ $ sudo kill 21338
ok, just in case node-red is auto restarting, for now, lets disable the service...
sudo systemctl disable nodered.service
node-red-stop
wait 10 secs
if you get a PID, kill it (use sudo if necessary)
wait 10 secs
Also, just in case, what does pm2 list show?
pi@raspberrypi:~ $ sudo systemctl disable nodered.service
pi@raspberrypi:~ $ node-red-stop
Stop Node-RED
29037 ?        00:00:07 node-red
pi@raspberrypi:~ $ sudo kill 29037
 2628 ?        00:00:06 node-red
pi@raspberrypi:~ $ pm2 list
bash: pm2: command not found
pi@raspberrypi:~ $ sudo pm2 list
sudo: pm2: command not found
pi@raspberrypi:~ $
Stop Node-RED
pi@raspberrypi:~ $
most strange.
What does systemctl list-unit-files | grep enabled show?
pi@raspberrypi:~ $ systemctl list-unit-files | grep enabled
apparmor.service                           enabled
autovt@.service                            enabled
avahi-daemon.service                       enabled
bluetooth.service                          enabled
console-setup.service                      enabled
containerd.service                         enabled
cron.service                               enabled
dbus-fi.w1.wpa_supplicant1.service         enabled
dbus-org.bluez.service                     enabled
dbus-org.freedesktop.Avahi.service         enabled
dbus-org.freedesktop.ModemManager1.service enabled
dbus-org.freedesktop.nm-dispatcher.service enabled
dbus-org.freedesktop.timesync1.service     enabled
dhcpcd.service                             enabled
dhcpcd5.service                            enabled
docker.service                             enabled
dphys-swapfile.service                     enabled
epmd.service                               enabled
fake-hwclock.service                       enabled
getty@.service                             enabled
gldriver-test.service                      enabled
hciuart.service                            enabled
influxd.service                            enabled
influxdb.service                           enabled
keyboard-setup.service                     enabled
ModemManager.service                       enabled
network-manager.service                    enabled
networking.service                         enabled
NetworkManager-dispatcher.service          enabled
NetworkManager-wait-online.service         enabled
NetworkManager.service                     enabled
nginx.service                              enabled
pppd-dns.service                           enabled
raspberrypi-net-mods.service               enabled
rc-local.service                           enabled-runtime
rc.local.service                           enabled-runtime
rpi-display-backlight.service              enabled
rpi-eeprom-update.service                  enabled
rsync.service                              enabled
rsyslog.service                            enabled
ssh.service                                enabled
sshd.service                               enabled
sshswitch.service                          enabled
systemd-fsck-root.service                  enabled-runtime
systemd-timesyncd.service                  enabled
teamviewerd.service                        enabled
triggerhappy.service                       enabled
udisks2.service                            enabled
vncserver-x11-serviced.service             enabled
wpa_supplicant.service                     enabled
avahi-daemon.socket                        enabled
docker.socket                              enabled
epmd.socket                                enabled
triggerhappy.socket                        enabled
nfs-client.target                          enabled
remote-fs.target                           enabled
apt-daily-upgrade.timer                    enabled
apt-daily.timer                            enabled
logrotate.timer                            enabled
man-db.timer                               enabled
You have docker running also?
what does docker container ls --all show?
pi@raspberrypi:~ $ docker container ls --all
CONTAINER ID        IMAGE                   COMMAND                  CREATED             STATUS                          PORTS        NAMES
b157d8141140        iotstack_nodered        "npm start --cache /…"   8 months ago        Up 20 minutes (healthy)         0.0.0.0:1880->1880/tcp        nodered
d0ffb0dcf660        portainer/portainer     "/portainer"             8 months ago        Up 4 minutes                    0.0.0.0:9000->9000/tcp        portainer
6fd87ed6c7ac        grafana/grafana         "/run.sh"                8 months ago        Up 17 hours                     0.0.0.0:3000->3000/tcp        grafana
3ea298f878b4        pihole/pihole:latest    "/s6-init"               8 months ago        Up 17 hours (healthy)           0.0.0.0:53->53/udp, 0.0.0.0:53->53/tcp, 0.0.0.0:67->67/udp, 443/tcp, 0.0.0.0:8089->80/tcp   pihole
c00039644b1b        eclipse-mosquitto       "/docker-entrypoint.…"   8 months ago        Up 17 hours                     0.0.0.0:1883->1883/tcp        mosquitto
12459a4bb6b5        iotstack_python         "python ./app.py"        8 months ago        Restarting (0) 49 seconds ago        python
7d40ae09cda7        influxdb:latest         "/entrypoint.sh infl…"   8 months ago        Created        influxdb
37433c30a475        openhab/openhab:2.4.0   "/entrypoint.sh gosu…"   8 months ago        Up 17 hours        openhab
2511dea17770        koenkk/zigbee2mqtt      "docker-entrypoint.s…"   8 months ago        Up 19 seconds        zigbee2mqtt
This is why you have port 1880 occupied.
Stop that container.
you have portainer - use that
I stopped docker. Run NR in safe mode and got this, is it normal:
pi@raspberrypi:~ $ node-red --safe
11 Jul 17:20:48 - [info]
Welcome to Node-RED
11 Jul 17:20:48 - [info] Node-RED version: v1.3.5
11 Jul 17:20:48 - [info] Node.js  version: v12.18.4
11 Jul 17:20:48 - [info] Linux 5.4.51-v7l+ arm LE
11 Jul 17:20:49 - [info] Loading palette nodes
11 Jul 17:21:00 - [info] Dashboard up and running
11 Jul 17:21:06 - [info] Dashboard version 2.20.0 started at /ui
11 Jul 17:21:06 - [warn] ------------------------------------------------------
11 Jul 17:21:06 - [warn] [node-red-contrib-usb/adkinit] SyntaxError: Invalid or unexpected token (line:59)
11 Jul 17:21:06 - [warn] [node-red-qnap-blockly/blockly] Type already registered
11 Jul 17:21:06 - [warn] [riot-xbee/riot-xbee] Error: Cannot find module '/home/pi/.node-red/node_modules/riot-xbee/riot-xbee.js'
Require stack:
11 Jul 17:21:06 - [warn] Missing node modules:
11 Jul 17:21:06 - [warn]  - node-red-contrib-mqtt-env (1.0.0): mqtt-env in, mqtt-env out, mqtt-env-broker
11 Jul 17:21:06 - [warn]  - node-red-contrib-mqttssl (0.0.5): mqttssl in, mqttssl out, mqttssl-broker
11 Jul 17:21:06 - [info] Removing modules from config
11 Jul 17:21:07 - [info] Settings file  : /home/pi/.node-red/settings.js
11 Jul 17:21:07 - [info] Context store  : 'default' [module=memory]
11 Jul 17:21:07 - [info] User directory : /home/pi/.node-red
11 Jul 17:21:07 - [warn] Projects disabled : editorTheme.projects.enabled=false
11 Jul 17:21:07 - [info] Flows file     : /home/pi/.node-red/flows_raspberrypi.json
11 Jul 17:21:07 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
11 Jul 17:21:07 - [info] *****************************************************************
11 Jul 17:21:07 - [info] Flows stopped in safe mode. Deploy to start.
2021-07-11-172752_1024x768_scrot
About mqtt-env and mqtt ssl:
2021-07-11-172920_1024x768_scrot
Yes, that is good / normal.
Now you need to find all mqttssl nodes and delete them, then deploy AFTER they are all gone.
Additional:
  • Are you using node-red-contrib-usb? If not, please uninstall that also.
With mqttssl the situation is the same like mqtt-env.
About node-red-contrib-usb- i wish to connect xbee modules via usb, so i assume that i need it?
No, you would typically use a separate application called zigbee2mqtt (installed to PI, not node-red) - then you communicate to the zigbee devices via MQTT or node-red-contrib-zigbee2mqtt (node) - Node-RED - so no, you dont need the USB node.
Can you share your flows
This is interesting, but how is better/easier to physically connect xbee to rpi- via usb or jumper wires?
Can't send the full clipboard, because it is too big. I can send pics of the flows, if you want?
@Steve-Mcl : xbee !== zigbee
ah, my bad.
then I can help no further I'm afraid.
I would suggest you clean up your flows, get node-red running smoothly then try installing the nodes you need one at a time & checking node-red still works. Post errors as and when they happen.
If you mean, that xbee !== (inequality) zigbee. In my case they are equal (xbee module contains zigbee protocol).
