Robotdyn ac dimmer
Hey all,
Newbie to the node red programming and working through it pretty well. I am wanting to create a reptile environment control system using a Robotdyn AC dimmer. I was wondering if anyone has used this or a similar hardware product. I want to use it to adjust the voltage and dim ceramic heat lamps to sustain a constant temp. My questions is if anyone has created a node that can adjust a PWM with zero point. I have no knowledge of creating nodes just using them.
If you know how to drive the PWM then <blatant plug> I suggest node-red-contrib-pid </blatant plug> for controlling it. You haven't said what device you are going to run on. I assume something like a Pi, in which case you could use a DS18B20 temperature sensor.
Hey thanks colin,
I am a pi 3b with the ds18b20.
I believe the standard GPIO node will do PWM.
Do you know how I could regulate, dim or adjust ac voltage without the device inward discussing
Sorry, I don't understand the question.
If you are asking how you might control the heater without the dimmer then the way I do it is using node-red-contrib-timeprop in conjunction with node-red-contrib-pid. Then you can control the heater with a relay output in the pi or an SSR.
@mjdula Have you realiszed it? I want to make some similar to adjust my to use only Photovoltaic. Do you have an excample flow for me, which I can use as a template. Or any other!?
This is a really cheap, well dimmer, so perhaps someone else use this.
